Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-23-2004, 10:07 AM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
Transmission NEED HELP
Ok I have a 1993 Lincoln Continental the transmission has not worked right since I have had it the car shifts from 1st to 2nd to 3rd but it will not go into 4th gear so the car only goes about 105-110kms then it starts to rev up I dont know what his could be the frist gears swich great it is just 4th gear that dont work.
Do you think that it is the transmission itself I have change all the fluids and filter vut it still does the same thing I have even tryed adding Lucass to the transmission but with no luck
Please help
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 08-24-2004, 02:29 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Transmission NEED HELP
Originally Posted by STINKINLINCOLN
....then it starts to rev up...4th gear that dont work...
Sounds like the OD band is gone. You'll be looking at a rebuild, or if you have the know-how you can replace the band yourself.
-Steven
1996 Town Car, Cartier
Old 08-27-2004, 04:02 PM
Is the OD band hard to replace?
69" BUICK RIVIERA
1999 OLD ALERO
Old 08-27-2004, 06:00 PM
Towncar's Avatar
Re: Re: Transmission NEED HELP
Have a look around the www to get some more ideas of what's involved in a transmission teardown, what to look for, what's mandatory in every teardown, etc....
Here's a good place to get you started.....
Give it some time to load, it's a huge page...
-Steven
Old 08-29-2004, 09:33 AM
Thanks Towncar Im also going to try lincoln Online
Thanks for all your help
69" BUICK RIVIERA
1999 OLD ALERO
