Old 08-23-2004, 08:39 AM
wweguy103 wweguy103 is offline
Banned
Send a message via AIM to wweguy103
Squeaking Help
This is probably a common thing, but whenever I turn my car on there is a very loud and long squeak. I thought it was my air conditioner because when I turn that on it squeaks, but it also happens when I turn my lights on and when i brake. It also happens when im just sitting there in park. I got this spray called Belt Dressing and sprayed it on and it didnt fix it at all. Any suggestions on what to do. Thanks
Old 08-23-2004, 09:46 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Squeaking Help
Check all your pullies. Make sure none of them are warped or loose.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 08-23-2004, 11:57 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Squeaking Help
What belt did you spray the dressing onto?
Might be the alternator belt
For Sale 98 Eclipse GS, 5 spd
Old 08-23-2004, 05:53 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Squeaking Help
Mine does it when it is colder out and it is the power steering belt.... your description is almost identical to mine... when I start my car the power steering pulley seems to lag a little.... new pump installed not too long ago...
I've tried to tighten the belt which is NEW and I just assumed that the belt is stretching a little...
I've been wondering if my alternator might be getting weak and close to replacement....130,000 on original alt...yah might be time
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 08-23-2004, 10:10 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Squeaking Help
You may need to play with the adjuster bolt(s) on your power equipment to adjust belt tension. If it sounds like a squealing belt, this is probably all you need to do to fix it. If it persists, you may need to put on one or more new belts
if they are not holding onto the pullies properly.
1996 Eagle Talon
Old 08-23-2004, 10:21 PM
96TSi's Avatar
96TSi 96TSi is offline
Send a message via AIM to 96TSi
Re: Squeaking Help
sqeaky belts are a very common DSM problem, just about every DSM i roll around with the belts sqweak when they turn em on(including my own)
best fix is tighten it up good but make sure you dont overtighten it.. we did that to a friends DSM and he busted his alternator belt
04 SRT-4
03 Evo
96 Talon TSi AWD *dead*
93 Talon TSi AWD *sold*
85 300ZX Turbo
90 300zx Twin Turbo
82 Karen
04 little boy
Old 08-23-2004, 10:46 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Squeaking Help
that sounds like a belt not tightened enough. i tighten my belts so that i can take and turn it so its vertical with my hand but not past vertical, then you know it's the right tightness.
95 Talon TSI AWD
97 Eclipse GST
Old 08-24-2004, 07:23 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Squeaking Help
my 4G64 sqeaked all the time, even after we changed all the belts, pulleys and tensioners.... it doesnt hurt the car if your worried about that, but it is embarassing and annoying.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-24-2004, 08:26 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
Re: Squeaking Help
my car squeaks too.. iv tightened, loosended, sprayed ect ect ect... so i came up with a solution.. i just turn up the radio...
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 08-24-2004, 08:35 PM
ashah000's Avatar
Re: Squeaking Help
Yes mine does too and its not a DSM if it does not squeak
Old 08-25-2004, 07:34 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Squeaking Help
Don't forget about the valve tap
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-25-2004, 10:05 AM
Re: Re: Re: Squeaking Help
The other day I started up my car and the tap wasn't there.... for a second I thought something was wrong
Old 08-25-2004, 11:25 AM
MasterBraetec's Avatar
MasterBraetec MasterBraetec is offline
Send a message via AIM to MasterBraetec
Re: Squeaking Help
I have been a Mechanic mt entire life although DSM's are fairly new to me (I have always worked for the Sheriff's Dept. so Crown Vic's I know well) and i have yet to see Belt dressing do anything but cost money my suggestion would be to check all your belts especially power steering and replace were needed
Never Underestimate The Power Of STUPID People In Large Groups !
Old 08-25-2004, 02:11 PM
ashah000's Avatar
Re: Squeaking Help
I dunno about that the belt dressing I have works quite well. Although it wears out quickly and the noise is back
Old 09-27-2004, 09:40 PM
BlackEclipse97 BlackEclipse97 is offline
Banned
Send a message via AIM to BlackEclipse97
Re: Squeaking Help
mine squeaks also when the engine is warm and i start it up i think its just a DSM thing
