Old 08-23-2004, 06:11 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
times from track
well this is my first time racing my civic at the track, not the first time i raced at the track but the first time i raced a standard at the track and the first time i raced my civic.
car info:
91 civic dx, motor is stock dpfi 1.5 with an intake. full interior plus 20lbs of tools.
very first run:
rt.......... .180
60......... 2.577
1/8........ 11.357
1/8mph... 60.924
ET......... 17.884
mph....... 74.891
best run:
5th run out of 14
rt.......... .125
60......... 2.600
1/8........ 11.330
1/8mph... 61.220
ET......... 17.815
mph....... 75.575
worse run:
13th out of 14
rt.......... .326
60......... 2.721
1/8....... 11.528
1/8mph.. 58.257
ET......... 18.229
mph....... 73.814
so what do you guys think ? what did some of you other stock dpfi motors run ?
Team Lonely Drivers
Old 08-23-2004, 08:37 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: times from track
You sir have some of the worst 60' I have ever seen
lol what were you launching at?
After all this time I always thought your car was modified more than an intake. Hmm
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-23-2004, 08:55 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
the best run had with my stock 1.5 dpfi engine was a 11.8 in the 1/8 but i am about done with my si engine so i will be goin back soon
KoRnSaQ
Old 08-23-2004, 09:41 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
on a 4-door DX, stock, I ran 18.078 @ 74, so your time seems pretty good. I have long since lost my slip, so I have no idea what my 60' times, etc..were
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-23-2004, 12:21 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Its so unfair, there are absolutely no tracks out here in southern california that I know about, everyone I have asked has told me that there aren't any. I really want to take my car to the track too.... Anyway... 20lbs of tools, what the heck ya carrying in there?
Travis
Old 08-23-2004, 02:09 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
I ran a 53.653 with a drill press, metal leathe, band saw, block boring machine.... man I was prepared that night.
Old 08-23-2004, 04:29 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
i ran an 18.5 with my stock d15b2 with no intake, and just the muffler, that was last year, i went to go back this year and it was rained out
Old 08-23-2004, 04:34 PM
well i tried launching between 3 and rev limiter which is like 6200 or around there. i found that i got the best times with a rev limit launch.
in my tool box was basic metric and standard sockets with the tools to change an axle because the axles i got in my civic were run without cv boots for a while so i was afraid that they were weak and might break. my whole tool box weighs almost like 60lbs.
my car at one point in time had a ls motor, but after i installed it and on intial start up i found that it had major rod knock so i pulled that ls motor out and took it apart only to find the crank was no good, 2 rods were bent and about to break, it grinded up 2 of the main bearings. but the stock motor had broken a timing belt but i never even tried to see if it ran, so after this ls incident i stuck back in the stock motor only to find 8 of the valves bent, so i pulled the stock motor out. picked up a 92 civic motor and threw that motor in and thats what i have now, still 1.5 and still dpfi. but i picked up another ls engine and that engine is going in as soon as i burn up this stock clutch.
so actually this is the first time my car has ran in 3 years. the car sat for almost a year because i knew it broke the timing belt so i was saving up for a swap, located a ls motor (the broken one) i actually got the motor a year and a half after i worked out the deal. after i found out it was broken took me couple months to locate and install that 92 civic motor, which sucked going back from mpfi and dewiring it back to dpfi.
Team Lonely Drivers
Old 08-23-2004, 04:53 PM
heres some pics of the broken ls motor.
here is #1 rod bearings, 3 pieces
here is #1 rod cap, can see the bearing from another rod and the space between cap and bearing
#1 rod, just alittle bent
and the money shot, the crank. just look at it need i say more. well incase people dont know what they looking at. the 2 visible rod jounrals burnt and scored, the 3 visable main journals burnt 2 of them scored
just a few pics of how the motor looked like when i took it apart
Team Lonely Drivers
Old 08-23-2004, 05:54 PM
Onimacus's Avatar
I can't see the pics
Travis
Old 08-23-2004, 06:05 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Damn, your finish mph is about my 1/8th mph.
Old 08-23-2004, 06:06 PM
try right click and show picture
anyone else having trouble seeing them ?
dont need to tease because my car is so slow
Team Lonely Drivers
Old 08-23-2004, 07:15 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
no pics...
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 08-23-2004, 09:41 PM
91civicDXdude's Avatar
i run 83mph in the 1/8 :P
Old 08-24-2004, 05:23 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
well i dont have a track near me for about 3 hours drive, i want to take it down but i havent had the time/chance to do it yet, not sure what i would get , im running road tyres on 17" rims, Short ram, header,exhaust, NO cat with a B16A1 in a EE9 VT
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
