Old 08-23-2004, 02:17 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Question bad synchro?
ok before i got my new clutch and flywheel put it, my car would grind a lot from 1st to 2nd maybe 80% of the shifts....when i got my new clutch and flywheel, it hasn't grinded at all....and when the 500mile break in period was up, it still didn't grind when i was hitting 7000 rpms....well tonight i hit 7grand and it grinded...i thought maybe i just missed it but i did it again, and yet another grind.....once more on the way home, and another grind....took it around the block, hit 7k once more and it didn't grind...it doesn't grind at all until i get around the higher rpms like 7k...and it seems like my car will grind when it feels like it...could this be a bad synchro? i know it can't be my clutch, flywheel, pressure plate or t/o bearing.
thanks for any help...
Old 08-23-2004, 02:32 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: bad synchro?
What fluid are you using? Try swapping in some BG Synchroshift and see if that takes care of it. Sounds like the synchro is going (and probably from a poorly adjusted clutch before), the fluid might buy you a few thousand miles before it gets real bad.
How close to the floor does the clutch engage?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-23-2004, 05:09 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
ya i would say synchro also,i was stupid one night and did some awd donuts in a gravel lot and went to shift into second and it grinded and did not go in.
PENNZOIL GM SYNCHROMESH WORKS GOOD ALSO,FOUND AT AUTOZONE FOR $4.99 QUART.
OUT COME: very stupid thing to do to a perfect awd tranny!
now it allways grinds in second,i regret it very dumb!!!!!!!!!!!!!!
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 08-24-2004, 10:40 AM
Re: bad synchro?
i dunno what fluid is in there but my mechanic said it was synthetic...my clutch engages about 2 inches from the floor.
Old 08-24-2004, 10:53 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: bad synchro?
Get that fluid out of the car unless it is OEM or the two listed above IMO
For Sale 98 Eclipse GS, 5 spd
Old 10-27-2005, 12:32 AM
laser apexi turbo laser apexi turbo is offline
Re: bad synchro?
My tranny just recently started grinding. One night i pulled up beside an identical car to mine. 1990 laser turbo both 5 speeds. Anyways. never felt a grind in this tranny before. then... shifting at 7000 and i felt it a bit... and all im thinkin is shit... here comes the dsm tranny grind again... anyways. It wont stop geting worse. just last week it started grinding while downshifting into 2nd. im gonna change thew fluids in it and if that doesnt help.. out comes the tranny.
