Old 08-23-2004, 12:14 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
headunit problem
ok heres my new problem first of all i got my car started and at home now (thank god was in a bad area were it was parked) but whenever my subs hit hard or the rpm's go under 1k my headunit shuts off and then comes back on. is this b/c the unit is shot or b/c of bad wiring
Old 08-23-2004, 12:40 AM
gtkriss gtkriss is offline
Send a message via AIM to gtkriss
how much power are you running to make those subs slap? It sounds like your alternator isn't putting out enough amperage to support the power demand that you system requires..
My new ride:
1986 Mercedes-Benz 2.3-16
Momo carbon fiber shift knob, Carbon fiber dash, New cooling system,
timing chain/tensioner, Blistin hydraulic shocks/coil springs,
Mcpherson struts, 17" Monoblock rims w/ Kuhmo tires.
with more to come!
Old 08-23-2004, 07:03 AM
600 watts but that wouldn't make the headunit turn off when it goes below 1k rpm when the music is off
Old 08-23-2004, 08:13 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: headunit problem
that sounds more like a wiring issue, maybe a bad connection somewhere. check your ground and the 12v source...
*Better power-to-weight ratio than a C6 corvette*
Old 08-23-2004, 11:11 AM
TechX's Avatar
TechX TechX is offline
Yeah a bad connection makes sense to me. If it was a weak alternator you would just drain the battery till the car would not want to start. Make sure your power (dist. block) and grounds are connected very well.
Old 08-23-2004, 12:26 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
nope nope nope. You don't have enough power going to your amp. sub hits hard, drains lots of power from alternator, as result, rpms go down and amp cuts off. all amps will cut off when they recieve less voltage than they require. just like when I didn't have a capacitor, my battery was draining, when it got down to a constant 10 volts my amp would cut off, I would have to reset it by turning the car off then back on. Sounds to me that you just don't have enough power coming from your alternator to support your system. Get a bigger alternator. Also, make sure that your amp isn't a piece of shit. Just about all the the cheaper amps (like the ones that advertise 6000watts for $40, non-brand name) pull a shitload of voltage and also make a lot of heat. They are not designed well; you get what you pay for. I would get a capacitor, 1 farad. When you sub hits, check you voltage gauge on the dash (not sure if 80's Camaros have that. if not, get a voltmeter) if your charging system is in good shape the meter will stay around 12-14volts constantly, if it is around 9-11volts then you need to get a new alternator (maybe new battery, but probably not). There is a possiblility that you've got a couple of wires switched somewhere (positive with negative) or grounding issues, that is causing the problem, but I don't think that is likely. Normally that tye of problem doesn't cause that big of a problem. I say more power.
How long have you had your system? A few months is normally the longest you'll have it before it starts to kill the charging system if there is insuffiecient power. Have you changed anything recently?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 08-23-2004, 01:11 PM
600w isnt going to drain his alternator...
Old 08-23-2004, 01:35 PM
twdz28 twdz28 is offline
Re: Re: headunit problem
sure it can...
get a 1 farad cap and retest
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 08-23-2004, 01:38 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
yeah i bet its the alternator
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 08-23-2004, 10:00 PM
StayOutofTheWay StayOutofTheWay is offline
Send a message via AIM to StayOutofTheWay
I have a system running at 2000 watts without a cap for about a year now, beyond a slight dim in the headlights I haven't had any problems with it. I had always planned to get a cap but never got around to doing it.
Old 08-23-2004, 10:11 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
my brothers trans am is doing that same thing, but his does it when he turns it up loud like it overloads the cd player. its a durabrand, it worked fine, but its got a 200 watt sony explode hooked to it and 2 10 inch subs.
Old 08-23-2004, 10:19 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
I had a 600watt amp with no cap and it didn't do that. I think either the amp has gone bad or there's a bad wiring issue.
Old 08-23-2004, 10:24 PM
korndogg's Avatar
that doesnt mean he didnt have a bad alternator in the first place though.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 08-23-2004, 10:29 PM
Hsmith117 Hsmith117 is offline
You need a new alternator soon. First check your wires and make sure everything is correct. Its weird that your RPMS affect your radio. If all wires are connected right the next step would be your altenator. 600w can be a load if you have a small altenator.. If you replace your altenator get a good one and a strong battery.. caps do help but are not needed. hope you find the problem good luck
Old 08-23-2004, 10:45 PM
NailZ69's Avatar
NailZ69 NailZ69 is offline
Send a message via AIM to NailZ69 Send a message via MSN to NailZ69 Send a message via Yahoo to NailZ69
i think it's your GROUND on the back of ur cd player not making good enough connection.
[]D [] []\/[] []D [] []\[]
"If you see my car on a trailer.....It's STOLEN~!"
