Old 08-22-2004, 11:04 PM
Zturbo's Avatar
Zturbo Zturbo is offline
HELP:Windshield
I'm builaing a merc s600amg.But the windshield crack and bend out of shape. is there any way I can fix this or cover it up.Will be great if anyone can help me.
Old 08-23-2004, 07:14 AM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Where is the crack and how big is it?
Old 08-23-2004, 07:27 AM
vwman's Avatar
vwman vwman is offline
You could tint the windows so you cant see the crack
-Mika
Old 08-23-2004, 10:55 AM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: HELP:Windshield
Unfortunately, you may have to make a new one. You can get clear styrene rather easily. Make a template with masking tape over the old part, place it on quite thin clear styrene, and cut it out. Carefully use epoxy to hold the new one in place, the epoxy needed to hold the complex curved shape, and care needed to not smear the epoxy around. That may be the best solution....
Old 08-23-2004, 03:17 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Re: HELP:Windshield
I have heard of another solution, but have not tried it. You'll need clear nailpolish and vaseline. First coat the window in vaseline and then apply the nailpolish in coats over the window. Apply coats and coats and coats of the stuff. When you are done, the vaseline should allow the nailpolish to peel off. I would think this would work even better if you worked with a negative of the window. But, like I said, I haven't actually done this.
Another solution is to replace the window.
I work slowly!
Old 08-23-2004, 03:53 PM
Tikiman's Avatar
Tikiman Tikiman is offline
That sounds like a brilliant idea, as long as the vaseline stays on. Would be interesting to try but i hope i never have to.
Old 08-23-2004, 03:55 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Re: HELP:Windshield
Hmmm, you could try putting liquid glue on the crack, letting it dry, then polishing the windshield out...... BTW, I haven't tried this, so attempt at your own risk.
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 08-23-2004, 04:20 PM
minniebanister minniebanister is offline
Re: HELP:Windshield
So you have TWO problems?
1. Windshield cracked.
2. Windshield bent out of shape.
But you don't say how bad either problem is.
Old 08-25-2004, 11:06 AM
Zturbo's Avatar
Re: Re: HELP:Windshield
It's bad,really BAD.. the windshild bent because i accidently left it under hot sun and it crack after I try push it back to place.
Old 08-25-2004, 03:13 PM
DSM-Mark's Avatar
Re: HELP:Windshield
That nailpolish windshield would be pretty pliable, I would think (meaning you could bend it to whatever shape you need). But it sounds to me like you should try to replace the window. If it's a Tamiya kit, you may be able to get the parts tree from the manufacturer.
I work slowly!
Old 08-25-2004, 09:36 PM
Zturbo's Avatar
Re: HELP:Windshield
how could I get a part tree
Old 08-25-2004, 09:47 PM
mike united's Avatar
mike united mike united is offline
Check the numbering of those parts (windows) on the back of the instruction sheet & order through HLJ or desired website.
I have my doubts you'll get one though as its quite an old kit, could be wrong though & hope you manage to get one. Im doing that kit too at the moment, checked my glass bits now, seem to be ok. Good luck..............
Later, Mike
Old 08-26-2004, 02:23 AM
Zturbo's Avatar
Re: HELP:Windshield
thanks man..I try to order it right now
