Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-22-2004, 09:27 PM
ahasver ahasver is offline
Send a message via ICQ to ahasver
rough Idle with a 94 explorer
while idleing my explorer vibrates every once in a while like the engine has a miss in it. i've replaced the fuel pump, and the fuel filter, the MAF sensor (had some acceleration problems MAF solved part of it.) now i have a miss and am at a loss for what is causing it. i have new plugs and new plug wires. when i step down on the gas to take off the car sputters and then starts picking up speed after a few sputters. i am at a loss. the engine light never came on. the ford dealer found zero problems other than the MAF sensor. so now i am stuck.
Old 08-26-2004, 01:38 PM
skamxxiii skamxxiii is offline
did u ever figure it out because mine is doing the same thing
Old 08-26-2004, 05:19 PM
not yet
not yet i was hoping someone here would have some insight. the only things i can think of are the spark box and the EGR valve. both together are about 200$ and fairly easy to fix. going to be a little while before i can afford them both. so i am waiting to see if someone has some insights to save me some money
Old 08-26-2004, 05:49 PM
ishop4less ishop4less is offline
Re: rough Idle with a 94 explorer
Clean your IAC Valve, if the valve stuck or dirty it will cause the problem.
