Re: 1994 2.3 liter bad gas milage help !!!!
im having teh same exact problem with my 94 v-6. from what ive gathered to fix this you should clean or replace teh mass air flow sensor, the MAP sensor, hte IAc (idle air control i think), and you will need to change the plugs if youve been running rich because tehy will be carboned up. also you may need to replace the o2 sensor again because it also will be carboned up if youve still been running rich. have the ignition coils checked too. another possibility is that you could have a bad cat converter, if it is plugged up i guess it can cause these problems. Finally ive heard taht it can be bad vaccuum lines that are causing the fuel pressure to be off which may cause rich running. all i know that i am better off taking it to an experienced mechaninc because i have dumped about $200 into fixing this myself and have had little to no success. you might want to consider just taking it somewhere before you wind up wasting your money too, it is such a long list of things that can cause pretty much the same problem that it is very difficult to narrow pinpoint and fix these problems
