Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-22-2004, 08:28 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
Engine Removal Help!!!
Ok I've started removing stuff out the bay to get ready and remove the motor in my 94 Integra Gsr. Just to be on the cautious side I would like some directions so im totally sure of what ive done, Anyone know where I could find a site or directions for Integra Gsr Engine Removal.
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 08-23-2004, 03:16 PM
sleeper97 sleeper97 is offline
Re: Engine Removal Help!!!
yah u should pick up a chilton repair manual for your car
Old 08-23-2004, 07:55 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
what happened? did u blow ur motor up? or just doing a tear down and rebuild?
well removing an engine is the easy part. puting it back in is a lil more difficult. just take a note of where all the electrical connectors, vacuum lines, coolant lines go. the install should be easy once u do that.
i would remove all the lines (electrical,vacuum,coolant) that run from the engine first. Unbolt and remove the intake pipings and your turbo/manifold. Then remove the axles, half shafts, then support the motor with a engine lift. Unbolt all the mounts (tranny mounts and engine mounts) then u should be ready to pop that sucker outta there.
but to be on the safe side, pick up a haynes/chilton manual if u dont have one already. Should be pretty simple to remove though
www.MEDIUMRACING.com
Old 08-23-2004, 10:59 PM
Rating's Avatar
Na the motor is fine, I just want a built motor, im actually selling the one I have.
Old 08-24-2004, 01:04 AM
integralover's Avatar
integralover integralover is offline
i did the samething that boosted said in pretty much the same order and the engine came out like a charm. the hardest part was getting it back in. went to start it up and realized i forgot to connect the return fuel lineand one of the coolant hoses going to my FIT valve. but it only took me two days of work to get it done. good luck though
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 08-24-2004, 01:33 AM
Rating's Avatar
yeah i got a haynes manual never heard of a chilton manual, maybe ill go lookin for it. Yeah ive started disconnecting, ill take a picture of it sometime, and show you how far i am, i have to do it little by little cause i work and sleep during the week. I think i get about an hour of work a day. Anyways, I baught the cherry picker and it didnt come with a sling or chain, what size chain should I use?
Old 08-24-2004, 02:21 AM
i did the same by doin' a bit at a time. i'm not sure about using a cherry picker for our cars. with the tranny and all situated the way it is, will make it harder to get out. if your doing it that way you will have to take the tranny out first and then the engine can go up through the top. i just lifted the front of the car up high enough to take it from the bottom. kinda wiggled it out that way. it only took about an hour to put back in from the bottom also. but from what i hear the best way to take out the engine is through the bottom.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 08-24-2004, 02:46 AM
Rating's Avatar
yeah i hear that to, the only problem is I dont see how I would get it out from underneath the car, I have a small 2 ton jack along with two 2 ton jackstands
Old 08-24-2004, 01:24 PM
what i did was is raise the car up as high as it will go with the jack, then took a second jack with boards underneath and raised it higher. did this untill it was high enough. i also went to walmart and bought one of those SUV jacks. its like a 4 ton jack. that damn thing will jack any teg up real quick. i think it was about $40? and this jack has come in handy alot lately. so it was really worth it.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 08-24-2004, 07:31 PM
yea, removing the engine from the bottom is a good idea! just drop the motor on a dolly and wheel it out. it will be easy to get the tranny and engine out at the same time do n it this way
Old 08-25-2004, 03:22 AM
yea forgot the dolly idea. that is what i did and it made that part damn easy.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 08-25-2004, 01:06 PM
Rating's Avatar
ok, instead of me going out and buying a dolly or whatever, on a cherry picker it has the long ass legs, couldnt I just lower it onto that and pull it out from underneath.
Old 08-25-2004, 10:48 PM
Re: Re: Engine Removal Help!!!
yea u could do that. but u can also try this: drop the engine on some cardboard or some hard plastic and drag that sucker out. have a friend help u push/pull/drag it out. u wont do too much, if any damage to the motor. but play it safe and drop it on something with wheels. using the base of the cherry picker will work just as good as the dolly. But arent u gonna be using the cherry picker to lower the engine to the floor? or r u gonna be using a hydraulic jack to do that?
Old 08-25-2004, 11:16 PM
Rating's Avatar
well I wont have to pull it out until after its dropped on the legs, here is an image off ebay, to show you what I got, and have to use.
But yeah Droppin it on the legs and then pulling it out from under, think it will work?
Im sure this image will leave after a certain period of time, so if anyone see's this post, sorry but the ebay image is gone ^^.
Old 08-25-2004, 11:47 PM
hmmmmmmmmm... i dont know if it will work. i dont think the legs of the picker will be able to go under the car if u r use n it to drop the motor as well. but maybe it will. can u remove that black bar on the top of the cherry picker (the part that the chain is attached to.) then place the chain on the top red part of the cherry pick. that should be good enough for u to drop the motor onto the legs of the picker
if i were in ur position, i'd try to see how hard it would be to lift the engine outta the car 1st, cuz if u have that same cherry picker in the pic, it will probably be able to lift the engine outta the car. ur gonna have to support the engine and tranny with the cherry picker, then remove all the mounts, drop the motor a little bit to swing it out so u can clear all the mounts, then lift up the motor outta the engine bay.
