Old 08-22-2004, 08:30 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Tranny fluid
Is there a dipstick to check transaxle fluid in 4th gen honda's ? if not how do check fluid?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 08-22-2004, 08:37 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Tranny fluid
there is a plug on the side of it, take it out and it should be level with thehole.
Old 08-22-2004, 09:14 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
automatics will have a dipstick tube that you can check your tranny fluid, sticks you have to check as described before....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 08-23-2004, 05:55 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: Re: Tranny fluid
level off the car and fill it with fluid... after it over flows, let it flow/ when the fluid flow level slows down to a drip - stick your finger in and check. it should be level with the hole, then plug it = your good !
Old 08-23-2004, 01:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
here is a diagram showing exactly where on a manual:
the auto dipstick is right on the tranny....can't miss it
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-24-2004, 10:04 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: Tranny fluid
If you decide to change the fluid, I'd recommend GM Synchromesh tranny fluid. It works pretty well...especially if you are having any grinding issues. It didn't completely eliminate mine, however, it did decrease it dramatically even after it's been grinding for 50k+ miles. You can buy it from gmpartsdirect.com for about $6/quart. - or from your local GM parts store for about $9 I think.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-24-2004, 02:15 PM
dagoEF's Avatar
dagoEF dagoEF is offline
[quote=sastanley]If you decide to change the fluid, I'd recommend GM Synchromesh tranny fluid. It works pretty well...especially if you are having any grinding issues. QUOTE]
I also agree on the Synchromesh stuff, I also threw some of that Lucas oil stabilizer in my tranny too, shifting is like slicing butter. That lucas stuff also quieted down the valve tapping by adding some in the engine oil. I would recommed it
Old 08-24-2004, 03:52 PM
Forunn Daberator
Re: Tranny fluid
dont forget to change your tranny fluid every 24000 miles (and filter if its auto). Most people say its not nessassary, but I definatly think it is.
Old 08-25-2004, 12:59 AM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: Tranny fluid
wiat dont our cars take regular engine oil either 10w-30 or 10w-40? But my car used to have 80w-90 which is what my friend uses in his 5th gen.
1991 Honda Civic DX Sedan
Old 08-25-2004, 04:58 PM
krustindumm's Avatar
krustindumm krustindumm is offline
Re: Tranny fluid
NEVER use plain motor oil. I have seen quite a few cars with regular motor oil that have grinding issues, after switching to Honda MTF they go away (or are drastically reduced, sometimes there is too much damage already).
Gear lube causes more damage than the motor oil as well.
IDK about the GM, but my guess is that it is gear lube with a friction additive.
91 Civic Dx Hatch
Midwest Honda's MySpace group
