Old 08-22-2004, 07:06 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
Question can it be done?
ight heres the scoop boys...in my friends nissan every time he drives he rolls down the windows and the back up when he parks (power windows) my question is it possible to have a toggle switch that when up would roll the windows down when the car is started and up when the engine is stopped???
Old 08-22-2004, 08:55 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
It is possible but you would have to change some wiring and find a way to drive that function from a relay. Its not worth it.
Old 08-22-2004, 09:10 PM
Phat_Jax's Avatar
Phat_Jax Phat_Jax is offline
Send a message via ICQ to Phat_Jax
Yes, in fact DEI has modules that do it if you have any DEI keyless/alarm/remote start piece...
Old 08-23-2004, 06:32 PM
1gspot's Avatar
Re: can it be done?
ya but im not talking about doing it remotely i want it to be all wired in the car. I was thinking u could hook it up so as soon as the ignition is on power goes to the windows in order to roll them down. however after a set peior of time the power would need to stop flowing there so that the windows could have normal operation. then have another switch that while power is flowing to it it breaks the circuit that would flow in order to roll the windows up. there fore the ignition turns off and the windows roll up. but do those kind of switches exist. a timed one and one that is controlled by electricity???
Old 08-23-2004, 08:08 PM
sofast's Avatar
Its possible im sure but to much of a hassle to bother with. It would take alot of wiring and a device to drive the relays that would power the windows down/up from the igition. Dont bother
Old 08-23-2004, 10:04 PM
Phat_Jax's Avatar
Yes, that is what the modules are designed to do...it would be a simple matter of wiring them to trigger on whatever you want.
The most common way is down on keyless unlock and up on keyless lock, however, you could wire the same module to a switch, ignition, your cigarette lighter, whatever the hell you wanted to...
Just like anything else electrical it doesn't care where the current comes from it just takes it the same...
