Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-22-2004, 07:05 PM
zerodiz99 zerodiz99 is offline
Unhappy Help b16b axles question!
I just did a complete jdm b16b motor swap in my 99 si except axles didnt come with the swap. I hooked up my stock axles and the car sounds and run like crap when i turn. I feel the lsd but i dont think the stock si axles work properly. Do I need new axles if so where can i get them?
Old 08-22-2004, 07:59 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Help b16b axles question!
I'm having almost the same problem. My b16b cv boots are torn open and none of the shops around here know what kind of axles will fit on it for replacements. I did a search all over the net and nobody knows.. and no, b16a axles will not fit, they are too long.
Old 08-23-2004, 02:47 AM
That sucks man.. i looked just about everywhere and the only thing close that says what axles were used in a b16b swap was in superstreet http://www.superstreetonline.com/fea...47/index1.html
but for the swap they used itr axles.. does that mean itr 5 lug conversion too? Please someone help!
Old 08-23-2004, 04:10 PM
Ricochet's Avatar
Banned
Yeah but did he use jdm or usdm itr axles..?
That car does have a 5-lug conversion so I'm guessing his itr axles have 23 splines unlike the civic's 21-spline shafts. I'm not to sure about that info though.. Anyways, my car is at the shop and they supposedly found a match to replace mine. When they call me tonight I'll ask what axles they used as replacements and will let you know.
Old 08-23-2004, 05:39 PM
Sounds good man.. hope everything goes well.
Old 08-23-2004, 08:09 PM
Ricochet's Avatar
Banned
They replaced them with oem 99-00 ABS Civic Si half shafts. Non-ABS shafts are too long, the ABS ones are just right. You can tell the difference between the two by the gear-looking ring around the end closest to the wheel. If your car doesn't have ABS brakes (which mine don't), it doesn't matter, they will still fit just fine.
Hope this helps.
Old 08-24-2004, 12:10 AM
Your refering to the non abs half shaft that doesnt come with the ctr motor correct? Thats right... CTR and ITR dont come with abs i believe. So the oem 99 si halfshaft should do it? And I can use my stock si axles?
Old 08-24-2004, 04:51 PM
Ricochet's Avatar
Banned
I'm referring to an abs-equipped Si half shaft, and yes, the ctr's came with ABS brakes. If your Si has ABS half shafts then yes, you can use them.
Old 08-25-2004, 04:52 PM
Where to get those axles?
Im going crazy .. the honda parts stores here in seattle washington carry parts for the non abs si. In the states si dont come with abs... where did you get you axles or where did the shop get yours? If you can.. may i get that number to the shop you went to?
Old 08-25-2004, 04:57 PM
Ricochet's Avatar
Banned
I got them at NTB (National Tire and Battery) here in Columbus Ohio. Their number is 614-761-0052. Ask for Kevin Gagnon, he's my buddy who put them in. Just tell him Ricochet sent ya
Old 11-02-2004, 12:43 PM
3k9civic 3k9civic is offline
Send a message via AIM to 3k9civic Send a message via Yahoo to 3k9civic
Talking xx
i dont think those si axles will works, isnt those axles are from sohc motor? then it wont work. try the 90-93 alxes, b16a2-a3 axles gsr axles or the itr axles. those should work fine any beseries axles to a bseries motor should work
Old 11-02-2004, 02:34 PM
Ricochet's Avatar
Banned
The 99-00 Si has a dohc B16A2, and yes, they did work just like I said. No, not all B-series axles will work with the B16B, just the ABS-ready Si axles. Also the ITR is totally separate from the rest. Do some homework and try reading the entire thread before showing your ignorance..
Old 11-04-2004, 12:52 AM
Woa this forum is old.. hehe I got the axles Ricochet recommended and they work perfect. thanks
