Old 08-22-2004, 06:40 PM
ewzar ewzar is offline
Camaro LT1 Engine Removal
I am a novice with a blown up engine. I need to remove it and I hve gotten as far as getting it on the jack but how do I get the engine off of the manual transmission?
Can anyone offer some help. Thanks
Old 08-22-2004, 06:58 PM
Deadcarny Deadcarny is offline
Re: Camaro LT1 Engine Removal
i dropped the engine and tranny out the botom still bolted together when I did mine. We did my buddies through the top and it was a PITA!
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 08-22-2004, 07:16 PM
Re: Re: Camaro LT1 Engine Removal
Thanks for the info. I would be very happy to have access to a lift but I don't. Looks like I will have to take the drive line off and slide the tranny back. I am not clear on how the tranny comes off the engine. I took the 6 bolts off the engine side of the tranny bell housing and thought the tranny would slide off but no joy!
Old 08-23-2004, 02:13 PM
you can do it in the garage though the bottom. Just get 2 sets of big jack stands. you need like 36" of clearance under the front bumper I believe.
1965 Ford F100
1992 Astro EXT AWD
www.SCFYB.com
Old 08-23-2004, 06:13 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
what the hell kindof jackstands do you have where you can get 36" of clearance!?!
and to the engine out in a garage i would think it would be easier to unbolt the tranny and do em seperately...
*Better power-to-weight ratio than a C6 corvette*
Old 08-23-2004, 06:59 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
prybar
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 08-23-2004, 07:07 PM
351wStang's Avatar
351wStang 351wStang is offline
See if you can lift the car up somehow, maybe ramps with jackstands in the back. Then slide under it and shake the tranny off of the motor. The input shaft runs thrue the clutch, and pp which is bolted to the engine. You have to have the splines in the middle of the pressure plate straight and not in a bind for the tranny to come off smoothly. If you are doing this laying on your back you may want to get someone to help you. Best of luck. The pilot bearing may be seized so you may need a prybar, and possibly a hammer.
1969 Cougar
357w & TKO - 475hp
Old 08-23-2004, 07:13 PM
89IROC&RS's Avatar
prybar........ and BFH
Old 08-23-2004, 07:47 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Ridge can lend you a hammer.
Old 08-23-2004, 11:02 PM
guy69buff guy69buff is offline
Send a message via AIM to guy69buff
remove drive shaft pull back tranny
Old 08-24-2004, 12:53 PM
The 36" only has to be under the Front Core support area and Front Fascia. You can buy some 6 ton jackstands that go up to like 27" or something, End have the rear lower with some Regular jackstands. this Should get you the clearance.
1965 Ford F100
1992 Astro EXT AWD
www.SCFYB.com
