Old 08-22-2004, 07:16 PM
ScorTmobileR ScorTmobileR is offline
Send a message via AIM to ScorTmobileR
amp not workin
hey got a pioneer amp, little one, hamie-down, not more than 200 watts. but i wanted to hook it up to my speakers. i have power going in and the ground connected. the cd plater is also hooked up. i have the amp running to one speaker just to see if it would work and nothing is happeneing. keep in mind this speaker is not attached to the cd player accept thru the amp. is that right?
thanks
Old 08-22-2004, 07:21 PM
also i forgot to add
i have no instrustion manual for the amp, i guess i could look on line, ill get to that.
and on the amp are five wires coming out to attach to two speakers or whatever there are two sets of two ( = 4) then a lone blue wire
what is it and what do i do with it?
Old 08-22-2004, 08:21 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: amp not workin
Check the fuses
Do you have the the remote wire connected (might be that long blue wire)
For Sale 98 Eclipse GS, 5 spd
Old 08-22-2004, 08:43 PM
cody911911's Avatar
cody911911 cody911911 is offline
Re: amp not workin
rca's connected?
1st rule of drinking and driving.......you gotta have a beer.....
Old 08-22-2004, 08:46 PM
yea the rca's are connected,whats the remote wire? and whats is connect to?
Old 08-22-2004, 09:24 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: amp not workin
the remote wire goes from your amp to your deck. It tells the amp to turn on. its usually a blue wire. at least all the ones i have seen are blue. and yes the speakers connect to the amp..not the deck.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 08-22-2004, 09:41 PM
ok that helps more but where on the deck does it connect? becasue it wouldnt connect to the car but to the deck, and i dont see any free wires except a blue wire for power antena.
Old 08-22-2004, 10:48 PM
ashah000's Avatar
Re: amp not workin
On some cars the power antenna wire can be used you need a signal to the wire when the headunit is on. What you dont want is a wire that turns on only when the radio turns on and turns off when the cd player is on.
Old 08-22-2004, 10:53 PM
i understand ill play with it tomarrow and figure it out
thanks alot for the help
Old 08-22-2004, 11:01 PM
Re: amp not workin
but if that doesnt work what shall i do?
Old 08-23-2004, 01:29 AM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
Re: amp not workin
try the power ant. line, if that doesn't work i'll walk you thru some more troubleshooting
THE DARKNESS!!!
an African Soup Bone Production...
Old 08-23-2004, 01:35 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: amp not workin
If it's an aftermarket headunit there should be a blue wire with a white stripe, this is the amp remote wire and it will be exactly what you want. If you have a stock headunit, I would use any wire in the dash that turns on and off with the car. This can be your ignition wire going to the headunit, power wire going to the cigarette lighter plug (if yours turns on and off with the ignition), etc. You have a lot of choices, you just have to find one that fits your needs and tap into it.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-23-2004, 01:05 PM
ok the power antena wire ( soild blue) worked perfectly thanks alot guys!
Old 08-23-2004, 01:54 PM
Re: amp not workin
ok.... well that was a short lived feeling of sucess.... after running it all for about five minutes there was some crackling coming from the speakers so i just turned the cd player off when i heard it. im triple checking all my connections but would that be it?
Old 08-23-2004, 02:44 PM
ok iw as talking to a friend who knows about this stuff but i was talking to him on a comp and it crashed...(not having much luck with electronics lately) but he started asking me if my wattage matched up i said yea im pretty sure but the amp is a hamie down and the guy told me it was 35Wx4 or sumthin like that so i figured i was good cuz my speakers have a max 150 and the amp is hooked up to 2 for now but soon 4.
its a pioneer GM-X302
and i cant find info anywhere to double check what i was told cuz its not witten anywhere on the amp
