Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 08-22-2004, 05:45 PM
opitica opitica is offline
Unhappy Ceiling Lights and Radio Out
Hello,
I have a 93 Lebaron LE that runs just fine. A couple days ago I took out my aftermarket Kenwood stereo to replace the wire harness and as i was connecting the new wire harnesses in (I hadn't thought to disconnect the battery) it did a little spark. Well, now my radio isn't recieving any power and my ceiling lights (courtesy lights?) don't work. Please help, thanks alot.
Old 09-17-2004, 02:01 AM
TheKhaos's Avatar
TheKhaos TheKhaos is offline
Heya. I've had a similar problem in my '93 Daytona. Look for a fuse panel on the inside of your car. Mine was under and to the left of the steering column. If you don't have one, look under the hood. Pop it open; you should see a bunch of plastic fuses and a diagram of what fuse does what. Find the one that corresponds to either the radio or internal lights (they're connected to the same circuit in series, so if one goes, they both go) and replace the fuse that is blown. My fuse panel had a few replacements, so I just replaced it with the same color fuse and it worked. I'd suggest disconnecting the negative battery cable before doing this though; I got a big ol' spark when I put the new fuse in, but luckily, it still worked.
Old 10-22-2004, 07:02 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
should be like a 15A fuse
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
