Old 08-22-2004, 01:26 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Popping/thud noise
When I turn my headunit on/off my subs make a popping/thud noise. It is the factory headunit and it is hooked upto the acc wire. I was told that a relay might fix this problem. Can it? Is this hurting the subs?
Thanks!
For Sale 98 Eclipse GS, 5 spd
Old 08-22-2004, 02:55 PM
KMoney28 KMoney28 is offline
Send a message via AIM to KMoney28
I had a similar problem. Even when the subs were off I still had the popping sound. The only way I could listen to the components was to remove the fuse for the subs. Turned out my amp to the subs was fried! Hope this isn't the case with you....
P.S. try taking the fuse out and see if ur vocals play, I'm sure the continuous popping isn't good for the subs.
Old 08-22-2004, 03:01 PM
ashah000's Avatar
Re: Popping/thud noise
It is not continuous popping it makes a thud noise when i turn the headunit on and then when i turn it off. Only those times otherwise the subs/amp play/sound perfect
Old 08-22-2004, 10:32 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
It's fine a lot of amps will "pop" or "thud" when they are turned on or off. Profiles thud when theyre turned off my Tsunami would thud when it turned on my brutus don't thud at all because it has quiet start. It's fine it's just the amp kicking on or off and sending a small signal to the sub no damage will happen.
Old 08-22-2004, 10:53 PM
ashah000's Avatar
Aight thanks, mine is a profile amp and now it is only making the noise when it is turned off.
Old 08-22-2004, 11:30 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
it's 1 of 2 things
1 - small turn on/off thump, a lot of cheaper amps have this, more expensive amps have protections built in to get rid of it. Nothing to worry about, but it can get annoying. Neither of my Avionixx amps did it when turning on or off, but if they were turned off and then immediately back on (like running them with the key in ACC, and then starting the car, they would turn off and then back on within a second) they had a pretty bad thump. My Linear Power and Cadence amps never thump though, but they both have delays built in to stop it.
2 - your amp has a DC offset and when it turns on or off the speaker cones move out/in to their new "zero" position. This can be very very bad for your speakers, depending on how severe the offset is
to check what it is, watch your speakers the next time it does it. Have a friend turn the headunit on or off while you watch the speakers. If it pops out or in and then returns to the normal spot then it's #1, if it pops out or in and stays there then it's #2.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
