Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 08-22-2004, 10:19 AM
1988suprakid 1988suprakid is offline
engine
if i have a non turbo 7mge motor is the block and the crank the same as 7mgte and if it is is what else is the same
Old 08-23-2004, 01:42 AM
SUPER_glu SUPER_glu is offline
Send a message via AIM to SUPER_glu Send a message via MSN to SUPER_glu
just about everyting is the same except the na supra has a little higher compression like 9 to 1 and the cam lobes are taller and the valve springs are slightly stronger if i remember right. if ur gonna go turbo keep ur block and ur head you will not regret it
Old 08-23-2004, 11:40 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: engine
The heads are the exact same, the blocks are the same design with some minor differences being the turbo has the oil squirters drilled and installed and an oil return for the turbo. The 86.5-88 n/a intake cam is different from all the others (all turbo and 89-92 n/a), some people have dyno'd a small gain with it but it could be explained by a number of other things. Turbo compression is 8.4, n/a compression is 9.2, the difference is the pistons. Crank, rods, lower intake runners and some other misc parts, it's all the same. If your going to turbo it why not just buy a 7mgte? It's not like there hard to find, and it's not like there expensive, Toyota did all the work for you and all you have to do is bolt it in.
