Old 02-06-2002, 12:52 AM
a007apl's Avatar
a007apl a007apl is offline
Banned
The Murciélago's Engine
The Murciélago's engine which complies with the strictest emission standards in the world, including those of the United States, Japan and Europe is a 12-cylinder 60° V with a displacement of 6192 cc, made entirely from aluminium alloy and designed for unleaded fuel, producing 580 CV (426 kW) at 7500 rpm and 650 Nm torque at 5400 rpm. Torque delivery is optimised across the entire engine operating band (even at engine speeds relatively low for a sports car) thanks to the adoption of a variable-geometry intake system (VIS), variable valve timing (VVT) on both inlet and exhaust camshafts, and the "drive-by-wire" electronic throttle control, which makes for reduced emissions, improved idle speed control and improved driveability. Particularly noteworthy is the fact that at just 2000 rpm, the Murciélago produces more torque than maximum value attained by the majority of Granturismo cars in today's market. Unlike its predecessor, the Murciélago has a dry sump lubrication system that allows the engine to be positioned 50 mm lower, with a consequent lowering of the centre of gravity. The variable intake system, which essentially alters the geometry of the intake system upstream of the primary intake passages, provides three different operating modes obtained by the opening and closing of two butterfly valves (one on the plenum chamber and one on the by-pass pipe), the operation of which is entrusted to the Lamborghini LIE engine control units. The VACS ("Variable Air-flow Cooling System") is an entirely new concept in air intake technology. A high-performance car obviously requires a high-power engine. And, in turn, a high-power engine needs an efficient cooling system with appropriately proportioned air intakes. In a conventional fixed system, these air intakes have to be dimensioned to suit the most extreme operating conditions, such as, for example, very high external air temperatures, even though these conditions are rarely encountered during normal running (accounting on average for only 15% of the vehicle's total usage). This means that air intakes have to be made too large for average use, thus compromising the car's aerodynamic characteristics and performance.
To avoid this compromise, Automobili Lamborghini S.p.A. has designed a variable air-flow cooling system in which the aperture of the air intakes can be altered to suit the cooling requirements of the engine and the external air temperature. As a consequence, the car's aerodynamic characteristics are only compromised when necessary, which, as stated previously, amounts to only about 15% of the total vehicle usage.
The essential characteristics of the system are as follows:
the system comprises two rear lateral air intakes that pivot to assume two positions: closed (O°) or open (20°). The change from one position to the other can be controlled either automatically on the basis of the operating conditions (engine coolant temperature and external air temperature) or manually, by the driver pressing a button (only with the engine running). The opening and closing of the air intakes is controlled by a dedicated PMC electronic control unit, the same unit that controls the movement of the rear spoiler. Should the movement of the air intakes be obstructed, a safety system alerts the driver by way of a warning light.
http://www.csc-online.de/imagescp/la...oak2_g_800.jpg
The Murci get it's revenge . . . raven1822 Murciélago (Murcielago) 24 06-14-2004 08:49 AM
Anyone can explain me why the Murciélago have changed its looking ? JESUS28 Murciélago (Murcielago) 21 01-06-2003 12:23 PM
Why that arrows near the murciélago gearbox? JESUS28 Murciélago (Murcielago) 6 10-10-2002 11:33 AM
New Wheel of the Murciélago a007apl Tires and Wheels 1 03-15-2002 07:28 PM
Murciélago engine video a007apl Car Videos 0 02-23-2002 11:12 AM
