Old 08-22-2004, 02:05 AM
pweiproduct pweiproduct is offline
Send a message via AIM to pweiproduct Send a message via Yahoo to pweiproduct
94 accord resonator pipe
anyone here got a replacement for my stock resonator pipe? it's got a big ass hole in it and the shop wants 250 to replace it. anyone got a used one in good condition or some sort of aftermarket replacement?
-pwei
Old 09-01-2004, 03:46 AM
kshawj kshawj is offline
Re: 94 accord resonator pipe
junk yard
Old 09-01-2004, 10:08 AM
Mr. Anderson's Avatar
Mr. Anderson Mr. Anderson is offline
Napa $114 do it yourself.. couple bolts, liquid wrench!
[img]
Old 09-01-2004, 05:15 PM
Re: Re: 94 accord resonator pipe
is that the exact part number i need? ie: is it going to be an exact replacement? or do i have to get some other stuff and some duct tape/hack saw to make it fit?
Old 09-01-2004, 06:31 PM
Re: Re: Re: 94 accord resonator pipe
No, it's not.. and only because more info for your car is needed. If you're car is VTEC or and "ex" like mine, OEM exhaust came with a different dual tip muffler, usually a little bit more expensive then the LX,DX... that's the $114. If you have a LX or DX probably going to be around $91. The only other thing you will need would be to replace the gasket between the resonator and the new pipe about $5. Tools needed:
Liquid Wrench
12mm socket and wrench
14mm socket and wrench
30minutes tops
Make life a little easier spray the hangers with liquid wrench too and they will come out of the rubber hangers alot easier. When you reinstall it, I put some mulitpurpose grease on the hangers to make them slip in real easy. Goto a Napa and just ask them and make sure you tell them what trim your car is to get the right thing. Easy as pie!.....
[img]
Old 09-02-2004, 09:34 AM
94hondaacc 94hondaacc is offline
go to a muffler shop,they can just change that part with a straight pipe, usually for around 70 bucks.
Old 09-02-2004, 05:42 PM
i was told i couldn't replace it with a straight pipe, that it would cause things to break. isn't the resonator pipe there to make sure that the exhaust system has sufficient flex?
god i'd love to have it replaced with something easier to maintain. anyone else know if this is ok?
Old 09-06-2004, 02:49 PM
ok i gave up and just got the resonator pipe.
