Old 08-21-2004, 11:51 PM
thunderloop thunderloop is offline
Question A/C problem (works after ~10 miles)
This has us stumped. The Air Conditioner on my wife's '98 Intrigue GL has been acting up lately. Recent system check showed full level of coolant and no leaks.
What's happening: The A/C turns on but blows warm air for 5-15 minutes before cold air begins to circulate (not a pleasant thing here in Arizona!). When I drove the car I noticed the A/C kept turning itself off and repeated pushes on the A/C button finally resulted in the unit staying on and cold air was produced. The wife thinks this was a quirk because the light stays on for her. (BTW, the A/C "on" light is really lame and often difficult to see in the daytime. So perhaps the unit was on and I was turning it off and on.)
Years ago I remember A/C units often acted up like this when a "thermo-coupler" was bad. I have no idea if the Intrigue has one of these but I am sure someone out there has experienced something similar to this and has an answer or suggestion before I spend big bucks by taking this one to the dealer.
Old 09-03-2004, 10:05 AM
pavel303 pavel303 is offline
hello
I know this problem i have same problem The problem is with AC/Heater Panel Tha inside you need to change the whole Controler .. what happaning is the nub that u turn that contorl amount of air to go to the car is going bad and you can try to pul it a lil twords you and see if it sloves the problem if not you need to get new AC/Heater unit that in ur dash board.
price range $300 and up
Old 09-04-2004, 04:36 AM
malcolm brumley malcolm brumley is offline
Re: A/C problem (works after ~10 miles)
I don't think this car has a thermocouple for the a/c. Make sure the condensor fan is running because it can cause similar indications.
macbrum
