Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-21-2004, 10:04 PM
Jaice Jaice is offline
Changing Spark Plugs and Fuel Filter
I have 2 questions.
I have an 89 Century Limited 3.3 EFI. I ant to change the spark plugs, but I was looking and there seems to be some type of silver boot or hose around it. Is there a major purpose for this. How would I remove it or is it possible to work around it to get to the plugs. I plan on changing the wires so would I need to transfer to the new wires. I think its just thin plastic but I want to be sure.
Second, I want to change the fuel filter, is it located inline with the fuel pump.
I haven't gotten around to buy a manual for this car yet
Old 08-21-2004, 10:20 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: Changing Spark Plugs and Fuel Filter
They're metal, to keep heat away from the plug wires. Use some channel-locks to get the wires off if you cant get a good grip. Fuel filter should be in front of one of the rear wheels.
Old 08-21-2004, 10:39 PM
Ok thanks, is it safe to remove them and not put the back? Also, for plugs, would Bosch Platinum2's be a good chioce since Platinum4's are so high.
Old 08-22-2004, 01:35 PM
tman's Avatar
Pimpin' ain't easy
I'd leave them there, but if it's too much of a hassle, remove them. However, the plugs may foul more quickly due to more heat generated.
I'd use only Delco plugs, bosch plugs are designed as generic plugs, whereas Delco ones are specifically designed for your engine.
