Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 08-21-2004, 09:42 PM
pilsner300zx pilsner300zx is offline
Unhappy 300ZX VG30DE NA No Compression
I was removing the pulley from the crankshaft & was trying to loosen the bolt while turning the motor counter-clockwise. I was feeling compression as I was turning the motor by hand trying to remove the pulley bolt for about 5 times than I lost all compression. The timing belt jumped a couple of spurs while removing the pulley bolt. I turned the motor over slowly & not much at all to find TDC of #1 & removed & re -installed the timing belt. I did a cold compression test & 5 cyl's are about 10 psi & 1 is reading about 60 psi. I was going to do a leak down because I am fearing bent valves. Any responses would be appreciated.
Old 08-22-2004, 06:56 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Re: 300ZX VG30DE NA No Compression
Bent Valves... Be careful finding TDC (Top Dead Center), when I did I smacked the valves again (go figure )
But it sounds like a valvetrain problem to me... Good luck bro.
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
