Old 08-21-2004, 09:15 PM
S-10kid S-10kid is offline
Send a message via AIM to S-10kid
Engine Power
ok i have a 2.2L 95 s-10. I am puttin a lift on it soon and i kno i will lose lots of power. I am want to put a turbochrager on it and exhaust and wat not. ANyone kno where i could find a used or new tbcharger for a good deal?? also wat about headers??
Old 08-21-2004, 11:43 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Engine Power
You won't really feel the power loss until you get bigger tires.
Your better off running a bigger motor than installing a turbo and exhaust. It would probably cost you less, and last alot longer.
Old 08-22-2004, 02:05 AM
Re: Engine Power
Naa dude a motor with a tranny is like 900 to a g a turbo i fofund is like 500
Old 08-23-2004, 07:45 AM
Banned
I know that a turbo sounds cheaper, and better but there are some things to consider when adding a turbo
- Turbo's work best with dished pistons
- Turbo's hate high compression, 8.5to1 is probably the highest that you should run
- Turbo charged engines run hotter, and burn out faster
- Most non turbo charged engines don't have a strong enough bottom end.
Plus a turbo charged 4 cylinder still doesn't have the stump pulling torque that you probably want
If you still want to run a turbo you should probably look for a good turbo core motor, and hopefully you can build a suitable motor for your rig using some of the parts.
An easier, and probably more affordable alternative is
- Make a Ram-Air system (I'm sure that there are free web-sites on the subject)
- Get a free flow exhaust system
- Look into a more suitable cam shaft
- If you still want more power, look into a NOS system. Just the smallest system should be more than enough to get you going.
If your truck isn't a 4x4 it shouldn't be too hard to change the gearing in the rear end
Good Luck
Old 08-23-2004, 09:18 AM
tazz311311 tazz311311 is offline
Send a message via AIM to tazz311311
Re: Engine Power
throw a small block in there. if that isnt enough power, throw a weiand 6-71 blower on there. if that isn't enough power, then youre just crazy
Old 08-23-2004, 11:06 PM
lowS-DIME lowS-DIME is offline
Re: Engine Power
you could build an entire trubo kit for under $600... and the 2.2 engine is a GREAT engine to turbo so dont sweat it. Turbo will be faster and easier to install than a new engine... Run a full exaust (DONT RUN DUAL, YOU WILL LOSE TONS OF BOTTOM END)... and then the turbo at like 7 psi.... it about 10-13 hp per pound of boost
plans for my new car....
