Old 08-21-2004, 05:25 PM
1.5 liter 1.5 liter is offline
Send a message via Yahoo to 1.5 liter
flywheel comparsion
does anybody know whats the difference between a 88 dx flywheel and a 91 si flywheel? i need this info cuz im changing my dx tranny to a 91 si tranny and i need to know if i need a si flywheel.
thanks
Old 08-21-2004, 06:12 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: flywheel comparsion
The 88 has a tiny 190mm/7.5 inches clutch disk size and the 91 has 212mm/ 8-3/8 inches clutch disk size. The 88 has 21 splines and the 91 has 20 splines. I believe that you will need to get a 89-91 flywheel and clutch to match the 1991 tranny because the splines on the 88 will not work..
Correct me if I am wrong.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-21-2004, 07:07 PM
Juicy05 Juicy05 is offline
Yeah the 88 and the 91 one wont match up for shit, the splines are different, i found this out when i bought my stage 2 clutch and flywheel from my friend who owns an 88. So they are NOT compatible.........
Old 08-23-2004, 06:22 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: Re: flywheel comparsion
that counds correct! = you need the 89 to 91 flywheel setup!
Old 08-23-2004, 02:08 PM
GTA's Avatar
GTA GTA is offline
Whee..
you can use the 88 flywheel but only if you get an 89 clutch. cause the surface area of the clutches are the same in 88-89 (200mm). If you want a clutch that has more surface are get a 90-91 flywheel and it will be 212mm
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
