Feul gage bounces only in park
I have a 2000 blazer an dI replaced the sending unit but now it only bounces in park.Where is the ground ?
Re: Feul gage bounces only in park
I dont know if this pertains to your model but here is the info for a similar problem with my car.
Engine Controls - Excessive Fuel Gauge Fluctuation Bulletin No.: 03-08-49-014A Date: October 02, 2003 TECHNICAL Subject: Fuel Gauge Fluctuates Between E and 1/4 Tank, Goes From 1/4 to Empty Too Quickly, Excessive Empty Fuel Reserve (Reprogram PCM) Models: 2001-2003 Chevrolet Blazer 2001 GMC Envoy 2001-2003 GMC Jimmy Supercede: This bulletin is being revised to add condition information. Please discard Corporate Bulletin Number 03-08-49-014 (Section 08 - Body and Accessories). This bulletin contains three different conditions depending on the model year of the vehicle involved. Condition # 1 (2001 4-Door Only) Some customers may comment that the fuel gauge goes from 1/4 to empty too quickly. Condition # 2 (2002 4-Door Only) Some customers may comment about excessive empty fuel reserve. Condition # 3 (2003 2-Door and 4-Door) Some customers may comment that the fuel gauge fluctuates between E and 1/4 tank. Correction Important: In order to select the correct calibration on some vehicles, you must first identify the cluster part number. This can be done using the Tech 2. DO NOT REMOVE THE CLUSTER. A new service calibration has been released to correct these conditions. Reprogram the PCM using the new service calibration, which was available from Techline starting August 25, 2003 on the TIS2000 version 9.0 or later. This calibration is an electronic calibration and is not available from GMSPO. |
Same thing happens to my 02k. It bounces all over the place from empty to full.
GOing to bring it in for repair monday. I will post their findings. |
bounces from empty to full ? It is probably your sending unit.
I replaced the sending unit and now it only fluctuates in park from E-1/4 tank.Can I reprogram it myself?
Does it do this when you are coming to a stop and putting it into park , or if you start it up in the morning it will do this?
Yes.
So you start up the engine and it will sit there and bounce?
This might be completely normal seeing you getting into the truck might have caused the gas in the tank to slosh from side to side a bit and when you are coming to a stop the gas will definitely be moving. How far does the gauge move? |
it fluctuates from E to 1/4
if you sit still will it gradually calm down?
Yes.But it doesnt bounce around in Drive?
It bounces in both park and drive, but more so when your sitting still.
A few times it has happened when going full speed, but mostly it happens while stitting in my drive way which is on an incline. |
Re: Re: Feul gage bounces only in park
It takes a minute to settle.
