Jdm BPT swap in a 92 protege?
I found me a 92 protege for 1500. I also saw the jdm bpt motor for 1400 which has 210 hp with 180lbs of tq. But it said it comes from the 323. Anyways can those motors fit in the protege? I want to know what needs to be done to complete this swap? Any info will be great!Thanks in advance
Re: Jdm BPT swap in a 92 protege?
it should fit in just fine....i've seen it done
Yeh but i want to know if its a str8 bolt on? I need to know what needs to be done to make it happen.
there are two kinds of bpt motors from japan. they both are direct bolt ons into the first generation protege. 1400 bux is a sweet deal on the gtr engine. usually u can get them for around 1800 without the shipping included.
Yeh i found it at www.totaljdm.com. I was gonna look at www.flashoptions.com but we'll see. So its a str8 bolt on...sounds swell 2 me.
check out www.clubprotege.com
they have all kinds of Protege FAQ's on swapping BPT motors... is the Protege you're talking about an LX or DX? The LX has the 1.8 DOHC which will mate to the BPT but if you have the DX w/the 1.8 SOHC you'll need an LX tranny to use the BPT.
1991 CRX SI (black) 15.3 @ 88mph (stock motor) '90 B18A1 swap Custom exhaust *2.25" piping *two glasspacks (inline) *polished flash-cut tip *exits pass. side, front of rear tire. '95 GSR 15" wheels 195/50/R15 Bridgestone Potenza SO-3's AE Eng. front crossmember Susp. Tech. 22mm rear sway bar Susp. Tech. 1.8" lowering springs Tokico Illumina 5-way adj. shocks Powerslot rotors Metal Master pads Goodridge steel-braided brake lines Red painted OEM calipers Skunk2 short shifter Skunk2 shift knob GT Grant steering wheel Red/black racing seats |
Thanks i needed that! Damn i haven't seen you on in awhile...
