| Off-Topic Talk about anything other than cars. |
The 1g Head..6-Bolt Engine or Head?
I'm planning to buy a 97-99 GSX. The question here is when i get one, should i do a full 1g GSX engine swap or jus the 1g head swap? I already know the future mods for it too. But wich is better to do in the 2g eclipse GSX? the full 1g swap or the 1g head?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
Re: The 1g Head..6-Bolt Engine or Head?
the full 1g swap
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
whats bad about doing the 1g head swap?
nothing but you have the risk of crankwalking the block! i'd just suggest modding the piss out of the motor and car until something happens (use it as a test bunny) so if something does fuck up you then can do the 6 bolt swap... dont fuck with a prefectly fine motor wait until something happens first! but if i were you and you really want to do the swap then do the full motor... easier to do now then to have the bottom end crankwalk/fuck up and have to do it later! good luck
theres nothing wrong with it, but you asked wich is best. and i think you would be way better off if you had the whole 1g swap. less problems.
yea i didnt want to mention the devil.... "CW"
Many people do just the 1g head swap. For 95-96, it requires the 1g CAS and anti-RM CEL measures as the full swap, so you might as well do it all. You can do just the head on the 97-99 if the block is ok, odds are it will never CW. You can also swap just the block and keep the 2g head, which makes for a little less work to the cooling system, but still has the RM CEL issues.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
i kno the 1g engine is better. Do you guys know the average price for installation for the swap?
