Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-21-2004, 01:23 PM
dukeofchurchill dukeofchurchill is offline
Send a message via AIM to dukeofchurchill
Front Disc Brake Rotors ?
How do you determine if you should replace the rotors when you do a brake job? The surface is smooth. Can they get to thin? If so how do you tell that they need to be replaced?
Thanks,
Russell
Old 08-22-2004, 05:36 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Front Disc Brake Rotors ?
Measure the thickness of the rotor using a digital caliper. If the thickness is less than what is stamped on the rotor then replace it. If it is not too thin, based on the measurement then you should be alright to use them again. To answer the second part of the question on can they get too thin, the answer is yes, but usually after they have been turned down on a lathe. They should not get too thin just by using them. Sometimes, however, you may find a set of rotors that were on the thin side when they were first put on the car by the manufacturer. In that case they cannot even be turned and must be replaced. If you intend to do your own brake jobs make sure to check the thickness each time you replace the pads or have them turned.
Old 08-22-2004, 05:44 PM
GTP DAD thanks for the info. "If the thickness is less than what is stamped on the rotor " Where should I look on the rotor to see the correct thickness?
Old 08-23-2004, 06:50 AM
Pontiac Guy
You should see a raised portion on the hub (where the lug holes are) of the rotor that will say minimum thickness and a number. Locations vary. If you can't find it check a service manual as they will also give you the minimum thickness.
Old 08-23-2004, 08:31 PM
thanks I will look.
Old 08-27-2004, 11:33 AM
DamienZ28's Avatar
DamienZ28 DamienZ28 is offline
If I have alot of miles on my rotors they are cheap enough that I just get a new set with the pads. Reusing them can cause warping problems later if they are to thin or not turned. Normally if im on a real tight budget at the time ill reuse them but the next time replacement. Mic the rotors to be sure and if unsure a place like autozone will measure them for you. Its always better to be safe.
http://www.fiawtcc.com/
2006 BMW 330i| 2009 Mercury Mariner Premier
Old 08-27-2004, 11:47 AM
I just replaced the pads. I have 55,000 on the van. So I will borrow the autozone tool next time. But I can see some thining taking place.
Old 09-14-2004, 09:57 PM
KJRich's Avatar
KJRich KJRich is offline
Send a message via AIM to KJRich Send a message via Yahoo to KJRich
Replace them if they're causing pulsing in the pedal (warped) and are too thin to be turned. Pretty simple.
Old 09-15-2004, 09:15 PM
KJRich I think that works for me. Thanks.
Old 09-16-2004, 08:35 AM
KJRich's Avatar
I like to think of it as the short version of what the others said.
