| Engine intakes, exhaust, turbos, nitrous. |
The guy@ my local performance shop told me I would be better off w/ a K&N drop in filter as opposed to JWT POP, b/c of stock G20 CAI snorkle. He said the POP takes in "hot air" and I eventually lose power. But I think the stock "snorkle" doesn't take in enough air?(I'm no engine whiz)
Is what this guy said true (or hot air) Are the K&N drop in filters any good (HP) Sorry if this was asked before, I tried to look for related topics and I know this ain't a real stumper. I trust you people more than> shop dude. Thanks! f-bOmb!:smoker2: |
Re: Hot Air ?
While moving, the air at the POP Charger will be within a few degrees of ambient. You are better off with the POP. A CAI will be better, but not because of air temp, but because the longer intake tube has resonance tuning effects that will increase hp.
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
I have a Ractive heat shielded filter and it do's a real good job of keeping the heat out, for example I used to run the top half of the stock air box with at k&n taped on wich made a difference in noise and performance but the tubing to the tb would get real hot after running it for a while so I knew I was sucking in hot air, now with the ractive I can run all day long and the tubing is still cool to the touch. Also the ractive was only $30 bucks and you can get a 3" MAF adapter to mount it, I know it dosn't have the venturi like the pop but it works fine for me and I saved about $100 bucks, plus the sound is realy cool.
05 Big Blue Stepside “Somebody kicked my dog Mavis and I’m going to find out just who the hell it was. I’m all messed up on cough syrup right now so just like nevermind.” |
i'd like to see a picture of this heat shield...
anyone know where i can get one for a p10??? -clifford
www.clearbrafilms.com |
Just wondering!
Just wondering!
Doesn't any of you guys have this shield under your gearbox with an "edge" on that makes the air go up around the engine!? It is standard in Denmark! And the temperature around the Filter is almost the same with this shield/plate as with the CAI!? Hop you can understand what I'm writing! It is a little difficult to explain, but I can try to take some pictures!
NISSAN RULES........... http://www.nissanklubben.dk
Here is an article an picture of it. You can find out more info by searching the web for ractive filter.
http://www.ctamotorsports.com/ractiv...tiveintake.htm You can get it cheaper then they have it listed for, I have seen them as low as $25. Hope that helps.
That Ractive filter looks restrictive as hell. I have my doubts that the "heat shield" would really do anything at all to shield away heat. If the air near that shield is hot, that same air is going to be what gets pulled into the filter. I think a person would be much better off going with a CAI or even the POP and an aluminum heat shield between the engine and the portion of the engine bay where the filter sits.
1999 Infiniti G20t 17" RH Evolution M7000's with Toyo's Mostly stock...for now. Klaatu Varata Niktu |
I have heard all of these arguments before I bought the filter but I figured for the price what the hell. I can tell you that the heat shield do's work compared to my previous setup because I have felt the temperature differences myself, I have the front of the intake facing the area between the battery and fender so it mostly pulls in air from that cavity which is why it gets colder air, and as for being restrictive it doesn’t seem to be lacking any airflow as far as I can tell it's seems much better then the stock intake (it feels like I have power all the way to redline instead of falling off after 6k) and even a little better then the open stock air box. I am not saying this will compare to a true CAI but for what I paid for it I am very happy with the results and I don't think that a pop will give much more, if any, increase over my setup.
I'm sorry but Ractive Filters suck, There a shitty design, i think you would be better of with a K&N filter instead of the ractive, My brother had on and it fell apart and it didn't do anything for the heat, plus with that design all the air is sucked in from one small point at the front of the filter instead of all around like a normal filter. I think the fact of the matter is if its under the hood a foot away from the engine its gonna get warm no matter what kind of plastic you use.
The guy at you local shop is a dumbass. If it were up to me i'd go back and ask him again and when he explains it start laughing at him. Then when he asks why you laughing just say it offical i have met the biggest dumbass on the planet. Why do you work here? Thats the reason why i won't even bother talking to those guys about mods and i come on here to get information from people that actually know about cars, my car in specific. I'd say go with a POP Charger or a CAI. My CAI was one of my favorite mods i did, it sounds good and it i gets cold as hell. The stock tube that runs down from the intake i believe goes down to the resenator which is a large plastic box with no openings, its been awhile since i took mine air box off and kicked it so i don remeber. But by adding a pop charger or CAI i think you will open up air intake system a little better then stock, so in other words its an improvement.
93.5 Infiniti G20 JDM SR20DE Lowered on Intrax, Hotshot Header and Hotshot CAI 15.90@88MPH http://community.webshots.com/album/34345621pASGoo |
ok guys, from those pics on the Ractive website- i designed my own heat shield...
i took a plastic red dixie cup and just covered my filter... thereby totally suffocating it... should work as good as the one those guys are selling for $35.00 if you want a custom one for your filter too from me- i'll sell these babies for a mere $9.99!!! GET 'EM WHILE THEY'RE HOT BABY!!!!!!! -clifford
:hehehe: :hehehe: :hehehe:
You need to add the extra filtering element in with that kit too, for extra protection... just add a big plastic bag that can be duct taped around the cup/filter to prevent any debris from coming in contact with the filter, maybe sell that kit for a mere $14.95 :hehe:
Justin McClanahan 95 G20 15.4 @ 91.4mph (2.4 60ft )143.7whp and 131.4 ft.lbs Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff... |
Ok, I'm sure that Ractive is not the best for our car other wise everyone would have one, I know that a CAI would be a 1000% better and I'm sure the pop is better quality and probably will give an extra pony or two. That said let me explain how I look at it. It doesn’t matter if you have a filter the size of the engine bay the air still has to flow through a 3" opening to get into the MAF, an open filter will and do's suck in hot air, the Ractive filter do's keep some of the hot air out because I have felt the difference (I don't car if Jesus comes down from heaven and tells me it doesn’t work, I have felt the intake tube before and after and with the Ractive it is cooler then with an open box). I paid $30 for a mod that I enjoy and I feel that helps the car's performance, I could have paid $130 + for a pop and got a whopping 3hp but I went a different route, I wish I had $250 for 8-10hp the CAI would give but unfortunately I have other bills that need to be paid first. These are only my opinions and others will differ but I figured I would share my experience to hopefully show that there are other options besides the norm. You can take any type of cone filter with a 3" opening and use a MAF adapter to mount it, or you can use a filter with a 4" opening and use the brass venturi inside the stock air box to mount it, any of these options will help your engine breathe better and are cheaper then a pop but you might get a bunch of people making fun of you for doing it so it is up to you.
http://www.rodmillenstore.com/is_300/intake.htm Although that kit is for a lexus is300- I was thinking that you found something similar for our little G20s. -clifford
Now that would be a nice setup.
