Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-21-2004, 11:27 AM
DeleriouS's Avatar
DeleriouS DeleriouS is offline
Send a message via AIM to DeleriouS
LS/VTEC Conversion
i want to do an ls/vtec conversion on my 95 integra. what vtec heads will fit on my block besides the b18c head? Any dohc vtec head??? thanks
Old 08-24-2004, 05:02 AM
almxdupintegra almxdupintegra is offline
Re: LS/VTEC Conversion
B16 head will fit thats what I am using.
FRIENDS DON'T LET FRIENDS DRIVE STOCK
Old 08-24-2004, 05:55 PM
boosted331 boosted331 is offline
No offense, but you're the kind of person that tries to do an LS/VTEC setup, messes up because they don't know a whole lot, ends up building an unreliable shit motor, and that's how LS/VTEC horror stories get started. Atleast now there are ways to make it much easier for an unexperienced person to do this conversion properly
Anyways. All B-series VTEC heads use dual overhead cams. Any B16, B18C1, B18C5, or B18C6 will bolt onto your head with the use of a set of dowel pins. For someone who has never done it before, I highly recommend running a golden eagle VTEC conversion kit, and replacing your stock headstuds with some ARP's while you're at it. If you have never pulled off your head before, to replace a headgasket or whatever, I recommend reading up now, know all the torque specs before you jump in.
Old 08-24-2004, 09:06 PM
DeleriouS's Avatar
Re: Re: LS/VTEC Conversion
[quote=boosted331]No offense, but you're the kind of person that tries to do an LS/VTEC setup, messes up because they don't know a whole lot, ends up building an unreliable shit motor, and that's how LS/VTEC horror stories get started. Atleast now there are ways to make it much easier for an unexperienced person to do this conversion properly
QUOTE]
Actually...u can take back your previous statement. Its people like you that make me not want to ask questions and learn on forums "no offense". I came here because i dont need some tuner shop saying..."
well hey...dont by a vtec head, by our turbocharger set for $2999.99 it so cheap!!!" i am sick of people trying to make me buy shit. my dad has rebuilt plenty of engines in his days, he would also be helping me with this. now with the b18c5 head...is anything different on that head because of the high compression pistons??? or am i good with that? and what was the b18c6?? thanks no offense man...
Old 08-25-2004, 12:30 AM
Re: Re: Re: LS/VTEC Conversion
B18C5 head will work fine, but no matter how much you've been told it will work fine ALWAYS check PV clearances. HERE is a great how-to if you've never clayed a VTEC motor before. B18C6 is a UKDM ITR motor.
The reason I said what I said is because it was somebody like you 3 or 4 years ago that tried to do an LS/VTEC setup when there isn't the knowledge that is around today, they messed something up, the motor used oil or didn't run right or whatever, and that's how the whole myth of the unreliable crappy LS/VTEC got started. Hence the "Atleast now there are ways to make it much easier for an unexperienced person to do this conversion properly "
Old 08-25-2004, 02:00 PM
DeleriouS's Avatar
Re: Re: Re: Re: LS/VTEC Conversion
How does this head look. I found it on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...917505145&rd=1
i know i have to get an oil line hook up and a new distributer and intake manifold...but tell me what you think...thanks
Old 08-30-2004, 10:00 PM
DeleriouS's Avatar
What do you think would be the best head for the conversion?
95' LS Integra
5spd
DC Header (4-2-1)
HKS Super Dragger Exhaust
Skunk2 Short throw shifter
Ground Control Coilovers
Strut Bar
-SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch
-SOON to be "home made" turbo charging (goal = 12psi)
-GOAL = 250-300hp with stock internals(probably not reachable)
Old 09-04-2004, 09:02 AM
Re: Re: Re: Re: Re: LS/VTEC Conversion
Oil line is correct, you need a new distributor or you can shave off a piece of it and it will work fine. Intake manifold must match the head such as a B16 head you need an intake manifold for a B16. You also will need a power steering bracket maybe from a GSR unless you dont need power steering. You can use GSR head bolts.
Old 09-04-2004, 12:41 PM
Kven's Avatar
Kven Kven is offline
Thats why you ask questions first and gain more knowledge before you do it.
best head would be whatever you can afford. the gsr's can make some higher compression but the intake manifold bolt pattern is different from the B16a and B18c5/r.
BTW, the only B-Series that wont work that i know of is the B20A(old prelude block).
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 09-04-2004, 02:49 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I think type r (c5) head and b16 has the best air flow. GO with that
Old 09-04-2004, 07:23 PM
I agreee with Mellowboy
Old 09-05-2004, 08:45 PM
DeleriouS's Avatar
sweet deal, thanks for all the info...i think i wanna go with the b16 head.
95' LS Integra
5spd
DC Header (4-2-1)
Strut Bar
Old 09-05-2004, 08:47 PM
DeleriouS's Avatar
[quote=Kven]Thats why you ask questions first and gain more knowledge before you do it. QUOTE]
DING DING DING! Thank you for supporting me. I deffinately would like to gain some kind of knowledge before I put this much stress on myself.
95' LS Integra
5spd
DC Header (4-2-1)
Strut Bar
Old 09-07-2004, 08:49 PM
DeleriouS's Avatar
Exclamation
Anyone know where I can get a VTEC head for cheap? preferably a b16 head...thanks
95' LS Integra
5spd
DC Header (4-2-1)
Strut Bar
Old 09-07-2004, 10:49 PM
mellowboy's Avatar
You might wanna try www.hondaclassifieds.com www.thepartstrader.com
Or go to www.hondaswap.com / www.honda-tech.com on there classifieds section. I've seen lots of goodies on there
