Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-21-2004, 07:18 AM
snowman81625 snowman81625 is offline
Question hesitation on acceleration 94 SSEI
My 1994 Bonneville SSEI hesitates when accelerating from stop. Otherwise the car runs and drives fine. No SES or codes are set. Does anyone have some ideas what the problem might be? Thanks
Old 08-24-2004, 05:23 PM
fastcarz3 fastcarz3 is offline
hey i got almost the same problem with mine hopefully someone can throw out some suggestions
Old 08-26-2004, 09:13 PM
Bonneville95 Bonneville95 is offline
Re: hesitation on acceleration 94 SSEI
I had the same problem until 2 months ago. I got the mass air flow changed for $195 CND + labour. Since then, my car doesn't only accelerate well but you should also see the performance on the highway. This part is located at the end of the duct between the air adimission filter and the motor, partly hidden, but you can see it. It's oblong, 1"x3"x6". I'm not sure if your problem is the same, but for the price, if that is the problem, you will notice a big change. If you want to be sure, ask your mechanic to sumbit your car to the scanner and then you will be fixed. Good luck
Old 09-15-2004, 01:40 PM
slimshady slimshady is offline
I had a small hesitation in my 94 bonne... i had fuel pump changed and filter it eliminate my problem.
