Old 08-21-2004, 02:45 AM
jms92 jms92 is offline
Question Can't get rear drums off 2000 Cav.
Was gonna inspect and replace rear shoes on daughters 2000 Cav. I can't get the drums off. What am I missing here? Other drum brakes I have worked on had a sloted hole to get at the star wheel adjuster, I don't see anything like that on these brakes. How do I go about compressing the shoes to get the drums off? Sometimes I really hate working on cars the simplest thing can really be a PIA!!
Thanks........
Old 08-21-2004, 10:55 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Can't get rear drums off 2000 Cav.
Well man... You don't have to compress anything. The drum should just pull right off. Unless it has been on there for sometime and has rusted to the hub. So if you plan on keeping that drum.. Get some penatrating oil (wd-40) or whatever and spray it around the hub. Next get a screw driver ( flat head) and work your way around the edges and pry that bitch off. If that dosn't work, i have used a welding torch and heated around the hub and sprayed more of the oil in there when it was being heated. Then i worked the screw driver and it finally popped off... Or you can always take a BFH ( big f&*king hammer) and beat that bitch off of there, i only did that when i was replacing the drums....Hope this was helpful.... good luck.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 08-21-2004, 12:01 PM
jayson716 jayson716 is offline
Yes use som penatrating oil and heat it with a torch but do heat to much might melt something and hit with hammer lightly then should pop off.
-Jay Jones
Team DROPZONE
Vice President
Old 09-02-2004, 12:53 AM
mrrob mrrob is offline
Helpful Hint Too.
Your Brake Drum may have a Ridge, therefore you may have to back off the shoe adjustment. Use a brake adjustment tool or small screw driver.
Good Luck!
Mr.Rob
Lic Mech Auto/Truck/Diesel/Propane/Trailer/ ASE
Old 09-02-2004, 01:05 AM
Sight N Sound's Avatar
Sight N Sound Sight N Sound is offline
You may need somthing like a impact wrench and they actually have an attachment that has a flat surface on it and it just beats the drum till the rust breaks free.
Old 09-17-2004, 03:10 PM
skinut skinut is offline
i'm sure you've checked this, but do not engage the emergency brake.
