Old 08-21-2004, 02:15 AM
wakraq wakraq is offline
Unhappy Help Me avoid orange peel!!
HI... I am new to this car modelling.... I have finished painting my cars.... All them have orange peel... I am using Tamiya Spray can. How to avoid this? I read about not having enough pressure.... Tamiya can are presurrised... How to control it? How about priming? do I skip this part or not?
I also read other threads saying about compund and waxing.... What is compuonding and waxing? How to use them? Can anybody teach me how to eliminate this problem. Help me please somebody.
Old 08-21-2004, 02:24 AM
hondaaccordboy21's Avatar
hondaaccordboy21 hondaaccordboy21 is offline
Re: Help Me avoid orange peel!!
read the f.a.q
:IN PROGRESS:
Old 08-21-2004, 02:36 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
You're most likely spraying to far away from the car. The paint is drying too fast before it can level out. I , myself spray only about 4 inches away from the body, And when I use tamiya spray can's I never get orange peel.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 08-21-2004, 07:34 AM
600sel's Avatar
600sel 600sel is offline
http://www.tamiyausa.com/articles/fe...?article-id=35
Old 08-22-2004, 09:32 AM
what do i key in or find in the FAQ
Old 08-22-2004, 09:49 AM
Vric's Avatar
Vric Vric is offline
http://www.tamiya.com/english/scale/beginner2/2.htm
Old 08-22-2004, 04:32 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
when you paint, its always best to lay down several mist coats, 4 or 5 mist coats until the paint fully covers the car, then as your final coat spray it a bit heavier,
your will still end up with a tiny bit of orange peel, and thats why you wetsand and polish, thats the only way you will get a mirror like finish.
Old 08-22-2004, 04:51 PM
scaleracecars scaleracecars is offline
Actually you can get a perfect finish out of a spray can. It just takes practice. Okay a lot of practice but it can be done.
David
Old 08-24-2004, 11:22 PM
Smile Re: Help Me avoid orange peel!!
Like I said i am not familiar with these terms. What is wetsanding and what do I polish it with? somebody please enlighten me on these things as I am still learning. Thanks...
Old 08-24-2004, 11:25 PM
JTRACING's Avatar
J.E.T.
its all in the FAQ, scroll down to the painting section
http://www.automotiveforums.com/vbul...d.php?t=215864
Old 08-24-2004, 11:31 PM
{(itchy)}{finger} {(itchy)}{finger} is offline
Send a message via AIM to {(itchy)}{finger}
wet sanding is using very fine grit sand paper (4000 grit-12000grit) to smooth out surfaces without ruining the paint job (you must work slowly to aviod sanding through paint coats) tamiya compound gets rid of small imperfections and a small layer of paint. tamiya polish shines your car... I personally primer on every car. the process should be sanding, compounding, and then polishing, but you might have to wetsand in between for a perfect finish. wetsanding in between primer and final paint coats also even out paint surface and add to a smooth surface.
Old 08-25-2004, 10:46 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
2 very important sections of this forum
the FAQ and the How To sections should cover what you need to know
http://www.automotiveforums.com/vbul...ad.php?t=63623
Freakin' Groovin"
Old 08-25-2004, 12:11 PM
600sel's Avatar
Just TAKE YOUR TIME to read..the faq and the links given.
