Old 08-21-2004, 12:25 AM
JonE JonE is offline
car trouble
hi, im having car trouble, i was woundering if any one could diagnos it. when ever you get to about 40-45 mph, and then u slow down to a stop, it stalls, it did that for a while, then just died on me. any one have any ideas?
Old 08-21-2004, 04:32 PM
public's Avatar
public public is offline
Re: car trouble
Sounds like a GM car with a bad torque converter clutch solenoid. If so the cure may be easy, may be a little difficult
Did I guess the car correctly???
Old 08-22-2004, 03:14 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: car trouble
Could be a bad or misadjusted throttle position sensor, or idle air control valve.
It COULD be almost anything. That's a very common symptom. If it's a newer car, I'd have the ECU checked for any error codes.
Old 08-22-2004, 04:19 PM
jimmy[the]gent's Avatar
jimmy[the]gent jimmy[the]gent is offline
could be the fuel filter, could be your cars idle is set a bit low ?
wat kind of car is it how old is it?
Old 08-25-2004, 03:35 AM
Re: car trouble
it is a grand am '92
Old 08-25-2004, 10:59 PM
public's Avatar
Re: car trouble
BINGO- See my earlier post. Unplug the thing to test it. If it drives normal then leave it unplugged. Good Luck.
