| Engine intakes, exhaust, turbos, nitrous. |
i want to advance my timing
i wanted to advance my timing to at least 15 degrees. but when i tried to, the only thing i got done was losing one of the screws for my distributor cap in my engine bay. i dont know much about this subject so any help would be thankful
did you search SE-R.net before actually doing it? id suggest researching something before you actually do it, and it might be costly if you dont
i did look on se-r.net and that didnt help me that much
se-r.net didn't help much?? never heard that before. they have a whole write-up on how to advance your timing. maybe you should check again.
Funny I found it in 30 seconds. Even has the procedure and everything.
About timing on the SR20DE What more do you want?
Hmmmm, last time i check my service manual it said that base timing was 15 degrees +/- 2 degrees, Perhaps i am wrong but i don't think 15 degrees would be considered advanced.
93.5 Infiniti G20 JDM SR20DE Lowered on Intrax, Hotshot Header and Hotshot CAI 15.90@88MPH http://community.webshots.com/album/34345621pASGoo |
But the stock position is 15 degrees BTDC (Before Top Dead Center) so theoretically it is 'advanced' already.
i really dont know jack shit about timing, thats why i posted this
15 degrees is the manufacture setting, 17 degrees is considered advanced and I believe it's the stock limit. No higher than 15 degrees if you have the JWT S3 cam.
:flash:
------------------------------------ paradyme 95'G20t/AUTO/BLK STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/ VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO |
Not many have been found to be set at 15-17 degrees from the manufacturer. So it should probably say 15 degrees with an error of -2 degrees.
Brandon '96 G20 - modified |
flyG20: Like said by everybody else don't attempt timing without knowing what you are doing make sure you have someone around that knows which plug wire to hook the gun up to and what the crank pully reading (as far as timing). Once you see how its done it pretty much cake after that though, Good luck:flash:
He's lucky 19 is pushin it. Is his engine N/A?
:flash:
Yeah, mine's NA. I have been running 19 for a while, almost a year now. I havn't had any signs of detonation, however I don't get on it at all in the summer time when it's over 100 outside... the car runs poor when it's that hot out anyway. On the dyno 19 degrees picked me up a few horspower over where i was previously at (15-16 degrees). Actually, i think it was 6 peak hp, not bad for a 3-4 degree change in timing. Also, i always run 91-92 octane gas. It was 92 until they changed everywhere in Az to 91
It may vary on different motor too, 19 may not be the best for everyone, It sorta depends on what mods you are running.
Justin McClanahan 95 G20 15.4 @ 91.4mph (2.4 60ft )143.7whp and 131.4 ft.lbs Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff... |
is the number 1 cylynder the one on the far left?
