Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-20-2004, 07:16 PM
dsa87gn dsa87gn is offline
dash/parking lights out
My dash and parking lights are out..
bulbs/fuses are good..
even replaced the headlamp switch..
any ideas ??
Old 08-29-2004, 07:30 AM
mesha0688 mesha0688 is offline
Send a message via AIM to mesha0688 Send a message via Yahoo to mesha0688
Talking dash and parking lights
I also had that happen. Under the hood on driverside of car is a box. It contains more fuses and relays. That was where my problem was. I had a short due to moisture corrosion. Two yellow butt connectors and a inline fuse holder my problem was solved
Old 09-11-2004, 07:24 PM
horsecore horsecore is offline
Re: dash and parking lights
I currently have the same problem. I found the blown fuse, but here is my dilemma. I looked on the underside of the fuse box, and where the fuse goes, there is only the orange wire still attached. There is an old corroded end on the opposite end, which I removed, but I cannot find the wire that goes with it anywhere. Is the orange wire the only one that is installed? I have a Chiltons and a Haynes manual, but the wiring diagrams are not specific enough and do not show the missing second wire, if there is one. Can anyone offer any suggestions? Thanks!
Old 09-13-2004, 07:55 PM
Re: dash/parking lights out
There isnt a mysteryt wire. The corrosion you see is from an "electrical bus" which used to serve as power to orange wire through the fuse.
I cut the orange wire and added an inline fuse, using the screw terminal that has the big red wire going to the bottm of the fuse box, all is well again.
