Speed Sensor
The Speedo in my 00 jetta 2.0 5 speed quit working and the check engine light came on also the fuel gage seem to fluctuate. I have a OBD 2 Computer a work and it says that the vss is giving the code. I replaced the speed sensor and no change. Is there anything else that could be the problem? Jer
Re: Speed Sensor
I've seen where the problem is actually the small plastic gear that drives the speed sensor. They usually keep them at VW & it isn't hard to replace.
Re: Re: Speed Sensor
Hi Boschman I have the same problem. I changed the VSS as well as the small plastic gear but the problem is not solved. In my case the speedo works sometimes and sometimes it doesnt. When the speedo doesnt work the odometer also doesnt work but when speedo works the odo also works. Please help! |
Re: Speed Sensor
Auto or manual? Are you sure you replaced the right speed sensor?
Re: Speed Sensor
Tachometer is driven off the ignition pulses. I believe the one to the rear, behind the engine is for the speedometer try pulling the wire to each of them & see which one kills the speedo to be sure.
Just a fuse
Looks like the problem was actually my reverse light bulb. It is conected to the same fuse that feeds the speed sensor. The bulb had a short in it and kept popping the fuse. If anyone else has this problem check fuse # 7 to see if it is blown. So much engineering in the car and they hook the reverse lights to the speedo. Good move. Thank's for the suggestions.
Re: Speed Sensor
Are you sure fuse #7 for the reverse lights was related, as I see no link to the speedometer or tachometer? I'd be interested to know if there was some definite relation such as if you pull fuse #7 the speedo quits.
