Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 08-20-2004, 05:44 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Exclamation help quick, cant get the drum cover off my rear brake drum
a brake spring broke and i got a kit to replace the damaged parts, i took my rear driverside tire off, then tried to remove the brake drum cover, i cant get it off. what am i doing wrong? i have tried wd40, i have tried beating it off with a sledge hammer (trying to free it up) is there some special tool for this. please help quick
Old 08-20-2004, 08:49 PM
groupset groupset is offline
The shoes are pressed outward against the drum, making it hard to remove the drum. Look on the backside of the drum; there should be an access slot (might be covered by a rubber plug - can't recall). Just insert a small-blade screwdriver into the slot to lift up the little tab on the starwheel adjuster - then insert another screwdriver through the slot and turn the adjuster up (I think) to retract the shoes away from the drum. Then you should be able to easily remove the drum.
Old 08-21-2004, 01:56 AM
superjoe83 superjoe83 is offline
Send a message via AIM to superjoe83
Talking Re: help quick, cant get the drum cover off my rear brake drum
is your e-brake off?
If it aint broke, fix it anyway
Old 08-23-2004, 03:59 PM
i finally got it off, my e-brake was on.
