Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 08-20-2004, 03:41 PM
wildchylld wildchylld is offline
Send a message via AIM to wildchylld
need wiring schematic for 92 Olds Trofeo
I need a dash schematic for this vehicle if anyone has one or knows where i can get one,thanks
Old 08-20-2004, 10:20 PM
Bill V Bill V is offline
Re: need wiring schematic for 92 Olds Trofeo
What is the area that you need help with?
Old 08-21-2004, 12:50 PM
Re: Re: need wiring schematic for 92 Olds Trofeo
Hi thanks for replying. My model has gauges not the digital dash. When the dash is plugged in my climate control blanks out and none of the gauges work nor does the driver info center. If i pull the gauge panel out the climate control works. Leading me to believe there is a wire crossed. My thought is that maybe someone changed it from digital to analog, and if so, is there a differant pin configuration for the gauge panel? Or is the gauge panel sherted out? Any thoughts? Thanks, Steve
Old 08-21-2004, 03:40 PM
This is a common issue with that instrument cluster. There is a capacitor that fails causing it to raise h*ll with the data bus. There are several places that will repair / exchange this unit. The one that comes to mind (because of it's name) is www.instrumentclusters.com. Try a Google search for "trofeo cluster"...
Old 08-23-2004, 11:50 AM
Cool thanks for the info.
