Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 08-20-2004, 03:36 PM
nyracer nyracer is offline
how to learn more about cars
hi i just wanted to know how i could learn more about cars and the parts that a car has and what exactly do those parts do.such a carborater chasis stuff like that. i would also like to know that these terms mean such as psi, and whp. what exactly do fuel injector do to.and for the future thank you if you answered.
Old 08-23-2004, 09:07 AM
Tbird4747 Tbird4747 is offline
all you really have to do is start surfing this web site and you'll pick up this stuff pretty quick. By the way whp stands for wheel horse power and psi stands for pounds per a square inch.
Old 08-23-2004, 11:54 PM
eightcylS10 eightcylS10 is offline
Re: how to learn more about cars
fuel injectors do basically the same thing as a carburator(spelling?), except carbs are controlled by the way u manually set it and fuel injectors are cointrolled my a computer that is mounted somewhere inyour car
88 S10-5.0 HO 305
- dualled exaust with thrush glasspacks
-removed CAT
-double roller timing chain advanced 4 degrees
coming soon..
-cam and lifters
-edelbrock performer series intake
-traction bars(badly needed)
Old 08-24-2004, 12:46 PM
Cryo boy Cryo boy is offline
Send a message via AIM to Cryo boy
Carbs are your air feul mixers. They distrubute the feul in a ratio with the air, this creates your air feul mixture, that makes the explosion in the cylenders that makes the crank spin, which makes ya go. feul injectors do the same thing as a carb. A carb puts feul in the air by sucking out the fuel using passing air in the venturies (those tubes in the carb, or barrels as they are reffered as) the air creates a vacume, which puylls out fuel, more air, greater vacume more fuel, so the mixture stays the same, injectors, just use a pump then they shoot feul in the air. Feel free to ask any questions
Old 08-24-2004, 12:47 PM
sorry, my grammer suks... never mind
