Old 08-20-2004, 01:28 PM
jroooo jroooo is offline
Static!
Ok so I started my 97 xj this morning with out a problem until I turned on the radio. Static! What the...! I could hear the static whine as the rmps increased so I'm thinking loose ground, right? Twenty minutes later I open up the door to step out and the static stops. Close the door, no static. Hmmmm... This afternoon going to lunch no static. Going back to work from lunch, static.
So again I'm thinking loose ground. Is that right? If so where would such a ground be located.
Probably not related but the grinding noise from my water pump that needed to be replaced also seems to be associated with the whining of the rpms. Is it possible that the dry bearings are building up a static charge?
Any insight?
Thanks!
Old 08-20-2004, 03:26 PM
dnparadice dnparadice is offline
I had an old ford that had a bad antenna conection that did that, it was close to the driver door so when you shut the door the motion would sometimes shake the loose wire on the antenna and make the radio reception go in and out. i finally fixed it with some good old electrical tape.
Old 08-20-2004, 05:45 PM
capt. apathy capt. apathy is offline
Re: Static!
the whine matches the rpms because a bad ground or a grounding of your antena is letting feedback from teh ignition interfere with your radio.
on mine the ruber had deteriorated at the base of hte antena and the part that should have been insulated was ocasionally finding a ground. when it did I had static that changed with the rpms. if I'd hit a bump or slam a door it would change, it was simply breaking the ground.
yours could be the antena, or a bad ground in the power for the stereo.
as to were to look. other than the obviose (where the antena wire plugs into the stereo or antena, and if the antena is mounted properly and in good condition. or wire conections from the stereo to the harness) it could be anywhere.
good luck hope you find it easy. one thing to help is to notice all of the things that change it (like the door thing you mentioned), and try and use them as clues to narrow down where it could be that all of the clues would have an effect on.
