Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 08-20-2004, 10:33 AM
illusion123a illusion123a is offline
rims
I just found out that both my rims are bent ( i only have 37 k and am a decent driver) so anyway i refuse to purchase new hyundai accent rims because they must have a pretty bad quality for both to go at the same time and at such low milage, anyway I am either goin gto go all out and get nice new rims or i am going to go really cheeply and try to find a set of rims in a salvage yard. ( i am leaning toward really cheep becasue i am going to be moving soon) What sizes will fit on my car, i would like to stay with the size i have now that way i do not have to get new tires. Will any rim fit, or do i have to look for accent rims? what are some web sites i can check out for rims, also what are the nemaes of some quality products?
Thanks.
Ps incase you cant tell i dont much about cars except for how to drive them!
Old 08-20-2004, 02:09 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Re: rims
Thanks.
I doubt there are going to be too many, if any wheels out there from other manufacturers that fit on that Accent. There are several different steel wheel options for an 02 Accent. You will probably need to pull the wheel off and there should be the part number stamped in the backside of the wheel. You will need that if you are looking for a used one. If you can get me your VIN number, I could probably tell you what the part number is, and possibly get you a good enough deal on a new one that you won't have to go used. Just let me know.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 08-23-2004, 03:37 PM
midnighted midnighted is offline
for the 2001+ accent models rims with a 4x100 bolt pattern and +40 to +45 offset will fit. 15" are ideal for the accent but you can go with 16" also.
go here for more info: www.hyundaiperformance.com
Old 11-15-2004, 05:38 PM
jerzralliart jerzralliart is offline
Send a message via AIM to jerzralliart Send a message via MSN to jerzralliart
Re: rims
i had a 01 hyundai accent with konig tantrum rims that were 17's tire size 205/40/17 when i had two people in the back they would rub only when you hit a bump but other then that i never had a probelm. and they made the car look 100% better
Old 11-15-2004, 05:40 PM
Re: rims
what r u talking about low, all you have to do is call tirerack.com or tires.com and ask what will fit your car there are hundreds of rims that fit hyundai when i was buying my rims i had a hard time picking which ones i wanted.
Old 03-28-2005, 02:08 PM
shortlid shortlid is offline
Re: rims
My friend bent the rim on his 2004 Accent GL Hatchback when he hit a storm grate going 10 mph! Should he get another manufacture of 13" 4X100 steel wheels seems like the stock ones are very weak.
