Old 08-20-2004, 01:51 AM
muzehyun muzehyun is offline
Send a message via ICQ to muzehyun
What kind of Engine Oil is good?
2000 Mustang v6 3.8
I purchased this car three month ago.
And today I changed Engine oil form Speed Lube Pennzoil
sticker on my front glass was 5w30
but speed lube changed that 5w20
What is different?
Which is better oil?
do I need to change oil another place next time?
thank you~
Old 08-20-2004, 12:07 PM
Cobra01TT's Avatar
Cobra01TT Cobra01TT is offline
Re: What kind of Engine Oil is good?
Those are the viscosity ratings, one is not "better" than the other. the deal with what temperature range they work in.
I don't know what the exact numbers are but I believe the 5 is -20*F, then the 30 would be able to withstand a higher temp than the 20.
The only better kind is synthetic oil. Several brands offer this; Redline, Royal Purple, Mobile 1, and maybe Amsoil. I use Royal Purple, but its a bit expensive for 6 quarts a pop.
2001 Ford Mustang Cobra - Straight piped and loud as hell
2002 Yamaha R6 - Micron exhaust
1987 Chevy Corvette Convertable A.K.A. - The Pimpmobile
Old 08-20-2004, 05:26 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
my cars get nothing but Mobil 1. i live in southeastern michigan and use 10W-30. My race car will get either Mobil 1 15W-50 or Royal Purple.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 08-20-2004, 09:48 PM
andrewespo's Avatar
andrewespo andrewespo is offline
I use Castrol Syntec 10W-40.
Old 08-20-2004, 09:56 PM
Tony H Tony H is offline
I use Havoline 10W-30 in most of my stuff. I dont find synthetic cost effective enough to use. I would use the 5W-30 like the manual says or 10w-30. You should be ok with the 5W-20 but the extra insurance is nice
Old 08-20-2004, 10:01 PM
eillob's Avatar
eillob eillob is offline
Will switching to synthetic cause a problem? Im thinking about switching to mobil 1.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 08-20-2004, 10:19 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
i use valvoline max life because i'm a sucker for advertising, but if i could find royal purple in my area i'd use it for sure. i hear beautiful things
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 08-20-2004, 10:28 PM
synthetic will actually gain you a trifle of power and increase longevity. switching to it from regular won't damage anything, but the other way around will. i used to drive an accord and switched to regular to save money. i didn't know that it would wreck my seals. fortuantely a can of Restore engine treatment sealed everything up (8 cyl formula). i shit you not.
-Andy
Old 08-20-2004, 11:10 PM
Future303 Future303 is offline
I believe you dude. I just got the all the oils done in my car, Engine, Tranny and Differential. I put Mobil 1 Synthetic in all.
Old 08-21-2004, 05:39 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Re: What kind of Engine Oil is good?
You! beat me to it...
1969 Cougar
357w & TKO - 475hp
Old 08-21-2004, 08:54 PM
brentmcq brentmcq is offline
I've been running Royal Purple but it's expensive as hell. I bought a case of 12 for $66. After that is used up I may look at Mobile1 if it's cheaper.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 08-21-2004, 08:55 PM
correction to above post it was $72.
