Old 08-19-2004, 11:02 PM
lawrence31 lawrence31 is offline
miss 97 silverado
97 silverado 4x4. engine missing on startup,losing small amounts of coolant.have not found any mixing with oil in crankcase.i suspect coolant leaking into cylinder then leaving via exhaust.is there a history here? laeky intake? or maybe a head or head gasket?how do i diagnose this problem.i have a pressure tester and a compression guage.
Old 08-19-2004, 11:18 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: miss 97 silverado
Yours is not uncommon, intake gaskets are prone to leaking. I tell everyone that has a 96-98 Silverado, Sierra, Tahoe, Suburban, Yukon, or Full Size Blazer to read my Super long informative Post. Hope this helps you. http://www.automotiveforums.com/vbul...d.php?t=267196 -Chris
Old 08-20-2004, 12:48 AM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
If water gets in the cylinders, then you will have white smoke coming from your tail pipes.
It's probably not a head gasket (all though it could be) because usually, when they blow you get excessive amounts of water in the oil. More then likely, your intake gasket is causing the problem. I would inspect closely around the intake for any signs of coolent (also, you could smell antifreeze).
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 08-20-2004, 01:26 AM
TweakedGM TweakedGM is offline
I have heard of the intake can crack.
