Old 08-19-2004, 11:17 AM
Phoenix69 Phoenix69 is offline
Water Sloshing Sound
Hey,
I'm a bit of a noob but when i drive my grand prix GT i hear a sloshing sound of water when i stop or drive away from a stop. It sounds like theres quite a bit of water sloshing around in the front (right?) side. I dont think it is the washer fluid. Is there anything that could have contained water or a drain somewhere that is obstructed?
Old 08-19-2004, 11:25 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Might be inside the HVAC box with the fan....since we do have problems with the drain tube that gets cloged and this may help you fix your problem Click Here ......~Larry~
ClubGP Member 6530
Since 2001
Old 08-19-2004, 12:11 PM
Re: Water Sloshing Sound
clogged aye? hmm
Old 08-20-2004, 05:40 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Larry,
Where do you come up with this stuff? You seem to be able to find information on anything. If I still had my company, I hire you. Jim
Old 04-13-2006, 12:17 PM
ss262 ss262 is offline
My friend has this same issue with her 2004 Grand Prix GT with 30K miles. Water noise is comming from the front passenger side of the dashboard. She took it to the dealer on Monday. At first they thought it was water leaking in from the firewall area. Then replaced the heater core and cleaned up any water that they found inside. Problem still occurs and their 7 techs are stumped so they moved it to level 2 and are having an engineer take a look. Did you ever find what was up with yours?
Old 04-13-2006, 12:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
This is a very old message thread. You might consider re-posting as a separate problem so people can weigh in to help you. Plus this old post was applicable to '97 - '03 GPs.
Timeslip 08/12/06
AF Community Guidelines
