| Off-Topic Talk about anything other than cars. |
OK I finally upgraded to a 1gen bov and have had it for a few days.... have been waiting for the adapter plate I got off of EBAY!!!! Finally today I got it!!! anyways...
First question is for the bottom of the BOV... There is about a 1/64 in recessed area off the side of the flapper with a 1/8 in hole... What is it for? Second question is there any type of gasket material anyone could suggest? I've got some permatex Ultra Copper sensor safe high temp RTV silicone gasket maker. Just by the name I assume this would be fine BUT I'd rather ask and be safe than to F anything up just by chance!!! I just want to get the damn thing in my car and get rid of my 2gen BOV... I got plans for it!!! Plans involve a torch and 2gbov
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
Re: 1gen BOV Question
I just went to pep boys and bought the gasket material (comes in a roll) and made my own gasket. I just cut it with a razor blade. As for the hole, I don't know what it does, I just know you can't cover it. Instead of torching the 2g BOV, why not sell it to some dude in the honduh forum.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
LMAO... good idea!!! It leaks though... but if they are dumb enough to buy a honduh they are the same for a leaky BOV!!!
I know you don't want to cover the hole.. I was just curious as to its purpose.. Thanks
It's a pressure reference.
Kris 2012 Genesis Coupe 2.0t |
just tell them it makes a really cool whoosh sound... they will get into a bidding war!
Re: Re: 1gen BOV Question
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
LMAO Vince!!!I ended up using some 1/16 rubber and cut it out as needed for a gasket.... excellent seal!!! ![]() So could a honduh really use this bov even though it leaks? If they only push about 5-6 psi ?
Lol joe, you ain't kiddin! Most of my honda friends are dumbfounded that stock boost is upwards of 15+ psi! They are even more amazed when I tell them that the 4g63 will take 400+whp on stock internals no sweat!
But yea, about the stock 2gen BOV; I'm selling mine along with my stock t-25 turbo to my friend that wants to put a small turbo on her integra
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
Coo ebay here it goes and i'll have to save the torch for another day.....
9-10 turbo honda's wont push more then 7-9psi. so that bov's perfect for what their going to use it for.
DSM geek |
HOw much hp do they get from pushin 9 pounds?
Typically, adding 15 psi of boost would double HP in a perfect world. In reality its a little less. Since atmospheric pressure at sea level is about 15 psi, anopther 15 psi of boost doubles the air into the motor. With the fairly efficient high output motors honda puts out these days, they do pretty well. On 10 psi the ex GFs '00 civic Si put out ~250 WHP. And the math works out.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
