Old 08-19-2004, 09:47 AM
89chevman 89chevman is offline
Question No "umph" after changing spark plugs
Hello,
Have an 89 Chevy K2500. Just changed all the plugs and wires (old ones had some carbon deposits on them. Also changed Dist. cap and rotor. Took it for a test run and truck is dogging. No acceleration at all. Also it keeps "spitting" off the #5 wire. Sounds a lot better than it did though. Also...wires are extremely hot!. Any suggestions?
Stephanie
Old 08-19-2004, 10:32 AM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
Re: No "umph" after changing spark plugs
Check that the wires are secure on the plugs and cap, and check to see that the wires are in the right spot. If that all checks out, check the gap on all the plugs.
Old 08-20-2004, 02:42 AM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
What kind of parts did you use (brand wise)? I have a '98 that I changed the OE plugs @ 60k to a set of Champion Platinum's and it ran alright. Also put on Accel wires but there was no significant change in performance. At 100K, I had learned the value of O.E.M. vs. aftermarket from current job. I kept the same Accel wires but put in O.E. AC Delco Platinums and WOW! I forgot my truck could run so damn well! the Champions also showed signs of excessive heat damage. And of course do as the reply above says too.
Old 09-18-2004, 10:22 PM
mattillac mattillac is offline
On my 1999 350 I tried bosch platinum plugs with a pre set gap (bosch specs) of about 35 and after that the truck ran with a rough idle at times with a check engine light storing a trouble code for the oxygen sensors but no noticeable power loss,I promptly installed brand new, more expensive factory ac platinums plugs with the larger gap which eliminated the problem......
Old 09-18-2004, 11:28 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
Maybe you got plugs that are hotter than they should be for your app. like this example. CR43TR or something like that. the position of the 3 is the spark temp reading. The higher the number the hotter. This could cause hot plugs and bad running, other than that whats listed above could be your problem.
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 09-19-2004, 05:18 PM
broughy84's Avatar
broughy84 broughy84 is offline
go with oem...keep your car gm
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
