Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 08-19-2004, 01:48 AM
isaat isaat is offline
Send a message via AIM to isaat
Question 2004 Gti 1.8
How Do I Get Rid Of The Freaking Drl (daytime Running Lights)
And How To Get Rid Of The Seatbelt Indicator?!?! Its Annoying!!!
Old 08-19-2004, 03:53 PM
boschmann boschmann is offline
Re: 2004 Gti 1.8
You can do it a couple of ways. If you use the relay method of disabling the DRL I suggest you tape over the TFL pin & keep the relay, as just removing it will also kill the park brake light.
http://www.bugmod.com/drl_tfl.htm
http://forums.vwvortex.com/zerothread?id=1293782
http://www.lightsout.org/disable.html
Old 09-30-2004, 01:19 AM
NovaKnowledgeNow NovaKnowledgeNow is offline
Send a message via AIM to NovaKnowledgeNow
seat belt light? simple Buckle up. Saftey belts are there for a reason. They work and are important. At over 30MPH you CAN NOT stop your self from flying out of your seat. Dont' believe me? drive down to va, and I will prove it to you without a doubt. They put them there for a reason. So buckle up, it's the law.
Now that I've lectured, you can take an easy way out. Go to a junk yard, cut the little piece "buckle" that goes into the the saftey belt off a junk yard. Just plug it in yours and there you go. Never take it out. Of course you'll be dead eventually because you dont wear it but whatever... Oh hey, can you put me in your will?
Don't bother replying to me on this forum. I rarely check these. IM me at NovaKnowledgeNow on AIM for further.
