Old 08-18-2004, 10:26 PM
danameisoj danameisoj is offline
eibach pro kit
im lookin into lowering my gst and was thinking of getting the pro kit instead of sportline . is there a big difference in drop or would it be better just to go with a sportline..??? has anyone had experiences with n e of these 2?
ps. i only want a 1.5 inch drop
when i get it lowered ... how will i be able to get the jack underneith?
Old 08-18-2004, 11:15 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: eibach pro kit
I am sure with a 1.5" drop you can still get the jack underneath the car. But you will probally need a camber kit also.
For Sale 98 Eclipse GS, 5 spd
Old 08-18-2004, 11:21 PM
Re: Re: eibach pro kit
i was reading on some other posts that if you go further that 1.5 you might need a camber kit.. ????
my 2ton jack barely goes under the car right now .. i have to remove the big circle piece to have it slide under
Old 08-18-2004, 11:29 PM
ashah000's Avatar
Re: eibach pro kit
Well I might be wrong about the camber kit then but how big is your jack? My 2 1/4 ton jack has ~3" of clearance right now. (my car is not lowered)
Old 08-18-2004, 11:31 PM
coolguycooz coolguycooz is offline
thats why you jack it up with the little small tire change jacks and then slide the other one in.
Old 08-19-2004, 12:24 AM
george536's Avatar
george536 george536 is offline
Re: eibach pro kit
or you can put two pieces of flat wood and drive up on them to give you a little more clearence.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 08-19-2004, 04:16 PM
correction i have a 3ton jack with 1/2-1inch of clearance
Old 08-19-2004, 11:22 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: eibach pro kit
go to any website/store that sells eibach springs and they'll tell you how much each one lowers it. i think the sportline lowers it 1.2" and the pro kit lowers it 1.7". you can also get ground control adjustables which are also really good. either way you'll need a camber kit if you don't want your tires to wear abnormally. you won't need one as much with the 1.2" drop just because they won't be as far off as the 1.7" drop, but they'll still wear quicker than stock suspension.
95 Talon TSI AWD
97 Eclipse GST
Old 08-19-2004, 11:32 PM
pro3racer pro3racer is offline
lol, reverse that, the pro kit lowers the car about 1", and the sportline lowers it 1.75". Yes, you'll want a camber kit, there not that expensive, and they'll save you a set of tires, maybe rims, and headaches.
Old 08-19-2004, 11:48 PM
Re: eibach pro kit
and just for the record......i need 3 2x4's and someone has to pull up on the car to get my little 3 ton jack underneath. don't even ask about changing a tire on the highway.
95 Talon TSI AWD
97 Eclipse GST
Old 08-20-2004, 12:34 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: eibach pro kit
guys, springs always sag more than the written lowering height. Springs for my spyder said 1.5"...yeah fckn right...after 4 months I was 2.25" lower than stock, and the rear fender gap was so tiny , you coulcnt even fit your pinky in there.
Get a Revo Technica camber kit. They are the best.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-20-2004, 10:23 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: eibach pro kit
luckly i live mext to the local auto club and we got a lift that liftd from the frame
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-20-2004, 10:24 PM
97_3clipse's Avatar
wow i need hooked on phonics!
Old 08-20-2004, 10:52 PM
Never Enough Power Never Enough Power is offline
Re: eibach pro kit
I went with the sportline because of the lesser drop. The Eibach kit is great, my GS-T looks great without the gap in the wheel wells now. Even with the smaller drop, you will have to use a couple of boards to get a jack under the car. Combine the springs with some stiffer struts (I went with KYB adjustable) and you'll be set.
Old 08-20-2004, 10:57 PM
i thought the sportline kit was a bigger drop, and the pro-kit was the lesser????
