Old 08-18-2004, 10:23 PM
s10frameoff1993 s10frameoff1993 is offline
Send a message via AIM to s10frameoff1993
Fuel Injector Problem - HELP NOW PLEASE
Hope someone knows something about fuel injectors. Vehicle is a 1993 S-10 pickup with the 2.8L engine with the TBI 220 throttle body. I bought new injectors, installed them, and don't think they are working properly. They are pouring the fuel into the throttle body. I thought they were supposed to spray the fuel in, sort of like a mist. The fuel right now is pouring in, and even dripping off the bottom of the injectors. Anyone know what could be causing this? What should I look for? Two things: (1) When the truck runs, the SES light flashes very quickly and constantly, which Chilton's Manual says the engine is running rich; And (2) The only code that pops up (when you ground out A & B on the computer plugin and turn the ignition on) is a Code 12. Something like "No Distributor Reference Pulses to the ECM". What does this mean?? Chilton's doesn't explain any more than that. What kind of problem is a Code 12? Is it normal and resets after a certain number of engine starts? Please help me!!!!!!!!!
Much Appreciated,
-Chris H.
~CS4LIFE~
www.csautoclub.com
Frame off on a 93 S-10 Pickup
Bagged & Layin' Frame
Chassis Is Molded And Painted
Suspension in ENTIRELY Chromed
Engine is Painted & Chromed
Polished Fuel Cell & Braided Lines
Stainless Steel Braided Brake Lines
"The more chrome the better"
Old 08-19-2004, 12:02 AM
dwinthrup dwinthrup is offline
Re: Fuel Injector Problem - HELP NOW PLEASE
injectors should spray in a fine mist and i would take it to a dealer
Old 08-19-2004, 05:49 AM
I wish I could take it to a dealer......Only problem is, with all the work I did to it, I don't think a dealer would touch it. I don't think I want a dealer to touch it, take the chance of leaving it there with $10,000 worth of chrome, a fully painted chassis, jet-hot coated headers, rims.....ahhhh, I don't think so. Can't do it.
~CS4LIFE~
www.csautoclub.com
Old 08-19-2004, 05:02 PM
big b big b is offline
CAR INSURNACE is a good investment.
Old 08-25-2004, 05:33 AM
DrKiss_7 DrKiss_7 is offline
Code 12 is normal with key on and engine not running. Ignore it.
Injectors should mist - have you checked fuel pressure and volume? Fuel filter need replaced?
Old 08-25-2004, 02:25 PM
dcg9981 dcg9981 is offline
sounds to me like you need to take the injectors back out and make sure you didnt rip the o-ring that goes on the bottom, i ran across the same problem in my blazer and i got a t-body gasket kit from autozone, it was like $5 and the o-rings fixed it, if you would like any more info e-mail me
